Drag wheel back space?
Old Oct 10, 2006 | 05:50 PM
89SiR's Avatar
Default Drag wheel back space?
I can't find an answer, and I have done a search.
I'm buying a set of 15x8" weld rims and plans for a 26x10" slick. I know a stock Honda backspace is 5" backspace. I'm needing to know if I should stay with the 5" backspace or go to a 4" backspace for more clearance.
89civic application with a typical cut for a one piece front end.
side question: do you think 26x10x15 inch slicks are too much for a 700hp range or should I go with 24's. (90LS tranny)
Thanks!
Old Oct 10, 2006 | 08:49 PM
A.E Motoring's Avatar
Default Re: Drag wheel back space? (89SiR)
i have a 13x8 weld wheel with a 5" back space, and they didnt even clear my gsr brakes, had to buy spacers
Old Oct 11, 2006 | 01:03 PM
ykracing's Avatar
Default Re: Drag wheel back space? (SPNFEDEH)
cant answer your backspace question, but you should definitely run 26x10...
if you are making that kind of power, and can fit them there is no reason to run 24.5.
(side note, Im selling some 15" bogarts w/MH 26x10x15)
Old Oct 11, 2006 | 01:53 PM
speedworks's Avatar
Default Re: Drag wheel back space? (ykracing)
i went with a 4.5 backspace on my bogarts. i might still have to run an 1/8 spacer though to clear the brakes
Old Oct 11, 2006 | 04:24 PM
89SiR's Avatar
Thanks for the info guys! Sorry ykracing I already ordered the rims from weld I just had time to change the backspacing. So I went with a 4" backspace and by the sounds of it I'll need the 26" slicks. Thats if I make the hp.
Old Oct 12, 2006 | 04:51 AM
ykracing's Avatar
NP... good luck, its not always as easy as people think!
prettyb0yvictor
Mar 7, 2011 11:20 AM
boosted.si04
Aug 18, 2010 01:18 PM
92 civic VX B18c
Jan 22, 2005 06:34 PM
cnydc2
Jan 19, 2005 03:03 PM
