obd-0 obd-1 coversion harness?
Old Oct 10, 2006 | 03:10 PM
puertoroc7976's Avatar
Default obd-0 obd-1 coversion harness?
is it really plug and play or is their some other things to be done i want to swap a z6 head on my d15b1 i have the p28 ecu ne sights on how to do this help want to start
Old Oct 10, 2006 | 03:57 PM
njn63's Avatar
you gotta run a few wires. On my Rywire harness i had to run 4 for the o2 sensor, 2 for the vtec solinoid, and i think there were a couple others. It's deffinatly not bad though.
You also need a 4 wire o2 sensor and obd1 distributor if you don't have those already.
edit: You also have to repin or somehow put obd1 distributor plugs on your harness. Forgot that.
Old Oct 10, 2006 | 04:31 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (njn63)
If you need any wiring help PM me
Old Oct 10, 2006 | 05:19 PM
blackcrx16's Avatar
i also need to know how to wire up a p28 ecu to my mini me setup (on boost). every one says its going to blow but i have tried over and over to blow it and it wont give, every thing is connected except the v-tec on the engine. but i would appreciate if it some one can help me out with the conversion.
Pancho2193
Mar 4, 2013 05:33 AM
88zchatch
15
Mar 20, 2009 12:06 PM
Fezzie
Aug 31, 2006 05:40 AM
Novtecdohc
Aug 18, 2005 06:32 PM
CanadaCivic
Aug 13, 2002 03:05 AM
