Tire Size Help!!!
planning on getting some 16x7's, whats the best tire size? and what is recommended? 205/50, 215/50, 205/45,215/45???? help!!! some picture will help also
OMG JUST FOUND A HELL OF A DEAL!!! I FOUND SOME FALKEN AZENIS TIRES FOR ONLY $160 WITH 80% TREAD LEFT. TIRE SIZE IS 205-55-R16. WILL THIS COMBO FIT ON MY CAR??? PLEASE TELL ME IT DOES I DONT WANNA MISS THIS DEAL!!!!!!
Modified by h22xcivic at 9:58 AM 10/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22xcivic »</TD></TR><TR><TD CLASS="quote">some picture will help also</TD></TR></TABLE>
Trust me, they won't.
What kind of car is this going on (make, model, engine, package...etc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">
got a 98 hatch with a 1.8 inch drop. the rims are 16x7. not sure why u need model and engine info for a mod to the wheels? hopefully this helps!!!
got a 98 hatch with a 1.8 inch drop. the rims are 16x7. </TD></TR></TABLE>
205/45-16. That size tire should be approved for a 6.5" - 7" wide rim so you are okay there. However I do not guarentee that they will not rub seeing as you are getting a tire that is 20mm wider than stock(which is normally okay) and have suspension mods. Try asking someone out there who has a similar set up.
not sure why u need model and engine info for a mod to the wheels? </TD></TR></TABLE>
Well, for example, the stock tire will change on an Accord depending if it is an EX, a coupe, a V6, a 4cyl...etc. With a hatch it shouldn't matter though.
Cheers.
Cheers.
Cheers.</TD></TR></TABLE>
do you think 205-55-r16 is to big? i dont wanna pass up that deal if they fit. they are 16x7 wheels. thanks!!!
do you think 205-55-r16 is to big? i dont wanna pass up that deal if they fit. they are 16x7 wheels. thanks!!!</TD></TR></TABLE>
Yes, too big for your car.
