Still need help on sway-bars
I want to know what I will need to install sway-bars on my 98hatch. I need lots of sugestions and info please. Im getting sick of rollin hard! If you have a hatch list your set-up and approx cost. Pics would be nice too.
Tame that body roll!!!
for the front if you want to use maybe a 96 00 civic ex bar (23mm someone correct me if i'm wrong) you will need to get the flcas off the ex civic.) or you could use the 99 00 si front sway (26mm) you would need the si flcas and forks.
for the rear you should already have holes there. just get whicher bar you want and it bolts right up.
you need 1, 2, 3, 4, 13, 20, 21 in the right quantities.
http://www.slhondaparts.com/br...=true
interesting, the Si 26mm bar is significantly cheaper.
i wonder if you can use a hybrid endlink to mount the bar since the Si endlink is two balljoints. the location might be too far off tho... not sure.
see, GSR endlinks are half bushing half balljoint endlink.
Modified by Tyson at 4:12 PM 10/10/2006
vega5415
18
Aug 19, 2015 06:06 PM
fireant
Suspension & Brakes
Mar 22, 2005 10:27 AM
MASTRCHANN
May 7, 2004 11:56 AM
