Pipe Beveling Tool
Old Oct 10, 2006 | 12:24 PM
Justin Olson's Avatar
Default Pipe Beveling Tool
Well, after 2 days of putting a bevel on 1.5" sch40 ss by hand, I am looking for a tool to do this and make my life easier. After cleaning and beveling about 20 side of pipe, I was having trouble welding. My hand torch hand was shaking all over the place. I was using a hand grinder with a sanding flaper disc wheel.
Anyway, what tool would you guys recommend for me to put a bevel on the end of piping?
Regards,
Justin
Old Oct 10, 2006 | 03:15 PM
y7turbo's Avatar
Default Re: Pipe Beveling Tool (Justin Olson)
its not mine i got the pic off the web. i dont have my camera on me, but you get the idea.
Old Oct 10, 2006 | 04:22 PM
drewzilla's Avatar
Default Re: Pipe Beveling Tool (y7turbo)
lol yea that's what I used to bevel mine. The pipe gets hot but it's better than using a grinder.
Old Oct 10, 2006 | 05:35 PM
Zornig's Avatar
Default Re: Pipe Beveling Tool (drewzilla)
Justin,
I use a large disc sander but a small 12" one would do the trick.
Jim
Old Oct 10, 2006 | 05:40 PM
Default Re: Pipe Beveling Tool (Zornig)
Could you guys post links to good models/brands to look at?
Regards,
Justin
Old Oct 10, 2006 | 05:48 PM
wade's Avatar
i feel justin on this as well
Old Oct 10, 2006 | 06:12 PM
GTiR NX's Avatar
I think a 5" Mini grinder is best for beveling pipe under 6". With a 1/4" thick disk lay it flat on the pipe while holding it at the angle of the bevel while moving back and forth in a faning motion. pice of cake.
Old Oct 11, 2006 | 05:46 AM
fabnewb's Avatar
Default Re: (GTiR NX)
thats what i do. Roll the pipe on teh table back and forth while holding the grinder on the edge. i have no problems beveling pipe.
Old Oct 11, 2006 | 08:17 AM
.RTErnie's Avatar
Default Re: (fabnewb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabnewb &raquo;</TD></TR><TR><TD CLASS="quote">thats what i do. Roll the pipe on teh table back and forth while holding the grinder on the edge. i have no problems beveling pipe. </TD></TR></TABLE>
dito. I usually put it vertical in a vice and use my 4.5" angle grinder and go around it.
Old Oct 11, 2006 | 08:32 AM
Howitt's Avatar
Default Re: (Eric@HorsepowerFreaks)
they make pipe beveling machines but they are $$$ ive looked in to them but using a carbide insert and build special fixture you can build one your self for a few hundred bucks
Old Oct 11, 2006 | 12:50 PM
SQ is the SQUAD's Avatar
how much are yall beveling the pipe? the piping i brought form ace stainless comes beveled, does it need to be beveled more?
Old Oct 11, 2006 | 01:03 PM
beepy's Avatar
Default Re: (SQ is the SQUAD)
Nah, the bevel is fine. We are talking about beveling after a cut.
Old Oct 11, 2006 | 02:34 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
the bigger the better.
Old Oct 11, 2006 | 07:12 PM
shortyz21's Avatar
Default Re: Pipe Beveling Tool (2point2)
yeah get a stand up grinder with lots of power.
u will bog that **** down
Old Oct 12, 2006 | 01:31 AM
el chupa nibre's Avatar
Default Re: Pipe Beveling Tool (shortyz21)
i use my belt sander and a 40 grit disk. takes 4 secs
my sander has a 52.5x4 belt and a verticle circular disc.
i use the disc. cmpared to the bench grinder its a walk in the park.
Old Oct 12, 2006 | 04:53 AM
TurboSI56's Avatar
This is what I use, with a custom made zirconia belt. It takes me about 5 seconds to bevel each side of sch 10 / 40.
Old Oct 12, 2006 | 06:01 AM
JG-Fabrications's Avatar
Default Re: Pipe Beveling Tool (TurboSI56)
I am hardcore use my rigid 4.5" angle grinder with 40 grit zerconiam flap disc
The disc last about 100-150 bevels each and I knock out each bevel in about 10 seconds, the discs dont heat up the metal and dont leave any burrs at all eather so there is no clean up when finished
-James
Old Oct 12, 2006 | 06:37 AM
RC000E's Avatar
Default Re: Pipe Beveling Tool (JG-Fabrications)
Belt sander....works good. Far easier, far quicker, with far more consistent results than the bench grinder approach.
Old Oct 12, 2006 | 08:11 AM
Default Re: Pipe Beveling Tool (RC000E)
The problem for me using the angle grinder to make a bevel is that it fatigues the muscles in my wrist and I have trouble being steady when welding after beveling 20 ends.
I'm going to look into a belt sander. That sounds good to me.
Justin
Old Oct 12, 2006 | 08:12 AM
Default Re: Pipe Beveling Tool (el chupa nibre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el chupa nibre &raquo;</TD></TR><TR><TD CLASS="quote">i use my belt sander and a 40 grit disk. takes 4 secs
What brand belt sander is that? Looks really nice
Ideally, I would buy a horizontal belt sander big enough to surface my head flanges after I've welded up the turbo manifolds.
Justin
Modified by Justin Olson at 9:33 AM 10/12/2006
Old Oct 12, 2006 | 10:07 AM
Howitt's Avatar
horizontal belt sander is not the right tool to surface flange with, use a surface grinder. they can be had for less than $500 at a auction
Old Oct 12, 2006 | 10:08 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el chupa nibre &raquo;</TD></TR><TR><TD CLASS="quote">i use my belt sander and a 40 grit disk. takes 4 secs</TD></TR></TABLE>
that's actually what I use.. (the 'disk sander')..
I have a 10" disk sanding attachment for my lathe and built a table for it. 40 grit is surprisingly smooth and it doesnt roll the edges over as bad as my bench grinder.
The bonus to having a disk/belt sander is that you can tweak and square the angles on the els easily and accurately. With a fresh sanding disk you can take 1/8" off in a decent amount of time but you better have a bucket of water around to dip the 'pipe' in every so often.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">horizontal belt sander is not the right tool to surface flange</TD></TR></TABLE>
It's the right tool if you want to screw up a head flange in a hurry.
Old Oct 12, 2006 | 04:06 PM
GeeGee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
It's the right tool if you want to screw up a head flange in a hurry. </TD></TR></TABLE>
can you elaborate on this please?
Old Oct 12, 2006 | 04:22 PM
2kjettaguy's Avatar
Default Re: Pipe Beveling Tool (GeeGee)
12" disc sander with a 1/2hp 220 motor. Nothing slows it down.
Old Oct 12, 2006 | 10:37 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeGee &raquo;</TD></TR><TR><TD CLASS="quote">can you elaborate on this please?</TD></TR></TABLE>
ok.
A flange may become warped after the welding process.
A belt sander is not the right tool for surfacing a head flange (making the head flange 'flat' so it mates with the head without leaking). A belt sander is meant for sanding.. after sanding the surface may look flat but I'll bet my left nut that it wont be.
A mill and a 'surface grinder' are what you should use to make surfaces flat and true. A surface grinder is the best method (but way overboard) and a mill does the job perfectly and is probably used in the factory.
If your manifold flange is not perfectly flat, pay a machine shop to "mill it". Dont be a douchebag and tighten is flat to the head - this can only increase your chances of getting a crack.
