running a 22mm rear sway bar.
Old Oct 10, 2006 | 11:10 AM
thehatchninja's Avatar
Default running a 22mm rear sway bar.
Does the CRX need chassis reinforcement to run this big of a bar? I know the EK's do especially.
Old Oct 10, 2006 | 04:20 PM
Default Re: running a 22mm rear sway bar. (thehatchninja)
subframe tearout FTL
Old Oct 10, 2006 | 04:34 PM
Crx Jimmy's Avatar
the bar doesnt attach to the subframe in the way the newer models do(dc,eg,ek), they have separate brackets that are bretty beefy and attach to the tow hook spots(ST bar anyway) so I would think if they are strong enough for your car to be pulled from I dont think they will tear out
Old Oct 10, 2006 | 05:07 PM
hughesl's Avatar
Default Re: running a 22mm rear sway bar. (Crx Jimmy)
I have been driving and autocrossing my ST for 4 years now with no concern. As stated above it attaches at the tow hook locations. The old tow hooks bolt in on top of the sway bar brackets.
Modified by hughesl at 6:22 PM 10/11/2006
Old Oct 10, 2006 | 11:25 PM
Tyson's Avatar
the difference as stated by others about the EF chassis is that the swaybar is not mounted on the subframe.
not saying its not ever possible, but it would be different and not a worry for you.
Old Oct 11, 2006 | 01:13 PM
thanks guys....that's why EF's are awesome
Old Oct 11, 2006 | 01:29 PM
rsca_crx's Avatar
Default Re: (thehatchninja)
progress bars do bolt to the subframe, unlike the oe-style bars.
i dd/autox'ed their 22mm for about 7 years and never had a problem.
tweek_boii
19
Nov 13, 2009 06:31 AM
88 EF Hatch
20
May 3, 2009 01:12 PM
fireant
14
Apr 12, 2006 11:43 AM
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
LCheung
Apr 18, 2002 08:01 PM
