Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
My NBP With Rota Boost, flat black??? Input for Winter setup
Old Oct 10, 2006 | 07:38 AM
06BlackSi #45's Avatar
Default My NBP With Rota Boost, flat black??? Input for Winter setup
I was looking at the 17 Inch Rota Boost, Flat Black for my NBP Si for my Winter Setup. What do you guys think?? Input guys. Do you guys like the color and what size would you reccomend? Thanks
Old Oct 10, 2006 | 09:31 AM
Type X's Avatar
Default Re: My NBP With Rota Boost, flat black??? Input for Winter setup (06BlackSi)
Winter rims should be as cheap as possible
i just got some 05 rsx type s 17's
Old Oct 10, 2006 | 09:41 AM
Default Re: My NBP With Rota Boost, flat black??? Input for Winter setup (Type X)
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">Winter rims should be as cheap as possible
i just got some 05 rsx type s 17's</TD></TR></TABLE>
Yeah true, but here in NC Winter isnt that bad. Its mainly so I dont have to ride on 19 with 35 series around town. The streets here are killing my rims and tires, you know. SO should I maybe get 16 inch with like a 40 series tire?
Old Oct 10, 2006 | 10:49 AM
Declectic's Avatar
then switch to 300000k HIDS after that, will be uber sick
Old Oct 10, 2006 | 11:11 AM
Default Re: My NBP With Rota Boost, flat black??? Input for Winter setup (SeanJohn1802)
Yeah, I cant wait to do my retrofit. I had 12K with no Retrofit, and it looked like ***. So I took them out until I can do the fit and use like 5K bulbs
Old Oct 10, 2006 | 11:39 AM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I cant wait to do my retrofit. I had 12K with no Retrofit, and it looked like ***. So I took them out until I can do the fit and use like 5K bulbs</TD></TR></TABLE>
you have an Si, my question is why would you want to put beater 16" rims on there?
you have 19's ... why not use stock rims for beater rims? i don't get it
Old Oct 10, 2006 | 12:01 PM
I'm not def getting 16's I was just asking opinons. I will prob go with 17's for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">you have an Si, my question is why would you want to put beater 16" rims on there?
you have 19's ... why not use stock rims for beater rims? i don't get it</TD></TR></TABLE>
I dont have stock rims, when I bought the car it came with 19's
Old Oct 10, 2006 | 12:11 PM
Declectic's Avatar
well if you look around, i've seen Si rims for as cheap as $250 (of course pick up only) just pick up some cheapy tires..some kumho 711s and you have a set of winter beaters
Old Oct 10, 2006 | 03:42 PM
COMplex.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">I'm not def getting 16's I was just asking opinons. I will prob go with 17's for sure.
I dont have stock rims, when I bought the car it came with 19's</TD></TR></TABLE>
Not from the dealer I'm assuming?
10
Oct 1, 2005 07:12 AM
SubTitle
Nov 11, 2004 06:05 AM
Wattup Though 00
21
Jun 27, 2004 09:21 PM
hitvtecgetloud09
11
Jun 6, 2004 12:20 AM
JDMRob
24
Jan 28, 2004 10:18 PM
