Intermidate shaft going into trans is leaking........!!!!!!!!!!!!!!!!
Do I need a new axle seal or new im shaft, or ? I poured trans fluid into the trans is it drained right back out like there was a hole... any suggestions would be great
sounds like you just need new seal in the transmission - the seal you need will depend on which intermediate shaft you have - if the shaft has a female end where the axle goes in, you need a seal for 90-93 Integra transmission - if the shaft has a male end that the axle fits on, you need a seal for 94 and up Integra transmission
I have a da suspenion I am going to get a seal and try that and hopefully that does it....
JRG151
Jan 21, 2010 05:27 PM
