suspension or direction issue?
Old Oct 10, 2006 | 03:17 AM
maxogsr's Avatar
Default suspension or direction issue?
I when drag racing this weekend and forgot to soft down my suspension set up in front...It's a daily driver track'n autocross purpose build car.
As I launch of the starting line, the front end start jumping very hard... As I was building speed, I started feeling something was wrong... I told my self you broke or bend something for sure. At first it felt like and unbalance tire but I switch them from back to front both side and it keep doing it. The car start shaking around 50mph. I don't feel it so much in the steering. It's the car that shakes a lot... Otherwise the shocks look fine, coils not cracked... I did 30 miles like that on my way back from track and I feel sometimes like the vibration was going away then come back. I't worst when i'm accelerating. The car dosen't pull either one side on accelaration or hard braking...
What could be wrong there? Tie rod? Ball joint? Axel driving shaft? Wheel bearing? Could I have blown the alignment?
Here's my set up:
-koni yellow+ gc (340 spring rate)
-energy bushing (front sway-bar + shock up n' down)
-energy engine mount bushing
-Enkei RPF1 + Hankook RS2 z212
-Brembo premium slotted + braided lines+ motul RBF 600
Anyone can help?
Old Oct 10, 2006 | 07:09 AM
IHTFP's Avatar
Default Re: suspension or direction issue? (maxogsr)
it could be a fuxored up axle if it vibrates only on acceleration...
does it do it at all speeds?? or just 50 mph??
Old Oct 10, 2006 | 07:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
One or both of your inner CV joints are bad. Bank on it.
Old Oct 10, 2006 | 01:23 PM
maxogsr's Avatar
Default Re: suspension or direction issue? (PatrickGSR94)
What do you mean by "bank on it" Sorry but I usually speak french. I'm bilingual but, this is the first time I heard that expression... And for the 2 nd post, yes I can feel something at low speed but nothing to write to your mom! It really start to get worst at around 40-50 mph...
Cv joint... I'm gonna check that tomorrow...
Old Oct 10, 2006 | 02:43 PM
maxogsr's Avatar
I have an other question for you... Let say it's the cv... Can I fix it or I have to replace it? If I have to replace... What would you buy? OE or after market? And BTW, I know ITR and GSR cv are interchangeble... Is there other OE cv that fit there... I would prefer an OE over an after market or rebuilt...
Modified by maxogsr at 6:43 PM 10/10/2006
Old Oct 12, 2006 | 02:09 AM
maxogsr's Avatar
Thank you, You were right on it...inner cv joint driver side. The bearing is fu..k up!... I know what i'm gonna do this weekend...
Have a good one!
Old Oct 12, 2006 | 06:28 AM
Community Builder
Bank on it = I guarantee it's true
Good job finding the problem.
superpilun
Dec 16, 2010 02:11 PM
mattbatson
Jun 25, 2008 01:25 PM
Mjfan12
Feb 4, 2007 04:55 PM
beyer
Oct 31, 2006 10:54 AM
speedracer33
Mar 9, 2004 05:47 AM
