Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
rotor question
Old Oct 9, 2006 | 07:03 PM
civ05se's Avatar
Default rotor question
Hi all,
I'm a newbie and this is my 2nd post. I have a 05 ex se and I'm a daily driver. At 30,000 miles, felt the rotors were warped because when I brake around 70 mph I felt a strong vibration on the steering wheel. So I took it to the dealer for a brake job because I got a discount. But instead of giving me new rotors, the dealer recommended me all it needed was some re-surfacing/cutting. 3,000 miles later, the vibration went from minor to strong again. So I've decided to replace the rotor. First question is if I'm going to order the parts from honda, which parts do I need to order? Is it just the rotor? Second question is since my brake pads are new, I dont think I need to replace them again?
Sorry for the long post. Btw, I like my civic and I've been getting ~39 mpg on mostly highway.
Thx.
Old Oct 9, 2006 | 07:08 PM
Miracle's Avatar
Default Re: rotor question (civ05se)
When I did my rotors, my dealership told me that they could not turn the rotors. And I only had 10k on mine when I upgraded the brakes. Wierd.
But to awnser your question, all you will need are a set of rotors and a set of pads.
Here is a DIY if you want to do it yourself. https://honda-tech.com/zerothread/1759074. It is a simple job, and you may be able to save yourself some money.
I went with a set of Brembo blank rotors, and a set of Hawk HP street compound pads, and have had no problems in more than 20,000 miles of driving.
If you replace the rotors, I would suggest replacing the pads. One, because you already have it torn down and apart. And 2, it is kind of like adding new oil to old. But if they are not TOO glazed over on the pad surface, you may be able to get away with not replacing them, but rather sanding them a little bit to get new pad material to seat on the new rotors.
Old Oct 9, 2006 | 07:45 PM
Vantage's Avatar
I strongly agree with Red, Pads+rotors when ur replacing everything.
I also agree with upgrading to brembo blanks, they are very cheap and SUPER good rotors.
And if u want a bit more stopping power, I will attest to the greatness of Hawk pads, i used them on my old CRX, and im just waiting till my stockers wear out before i put brembo's+haws on my EM2
Old Oct 9, 2006 | 08:11 PM
03EM2guy's Avatar
Default Re: (B18a_CRX)
i have a lil high pitched squeel come from front left, it stops when i put on the brakes ...i can only hear it at low speed
you guys think it might be like a lil rock in there like the dust sheld or somethin?
i was also thinkin about the brembo blanks and the hawk hp pads ... how much did you guys spend on them
Old Oct 9, 2006 | 08:40 PM
Vantage's Avatar
your brake pad could be on the squeeler, meaning it has to be changed.
check out prices of brakes at http://www.dezod.com
they are the lowest ive seen so far.
Old Oct 9, 2006 | 08:45 PM
03EM2guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18a_CRX &raquo;</TD></TR><TR><TD CLASS="quote">your brake pad could be on the squeeler, meaning it has to be changed.
yea i was thinking that until it only sounded when i was driving, every time i barley touch the brake the sound goes away
Old Oct 10, 2006 | 04:54 AM
03EM2guy's Avatar
Default Re: (03EM2guy)
not sure......i hope its just a rock b/c im prob gonna order some brembo flats and hawk pads and i need time for those to come in
im gonna go home today and jack it up and see what i can find
Old Oct 10, 2006 | 07:29 AM
civ05se's Avatar
Default Re: rotor question (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">When I did my rotors, my dealership told me that they could not turn the rotors. And I only had 10k on mine when I upgraded the brakes. Wierd.
If you replace the rotors, I would suggest replacing the pads. One, because you already have it torn down and apart. And 2, it is kind of like adding new oil to old. But if they are not TOO glazed over on the pad surface, you may be able to get away with not replacing them, but rather sanding them a little bit to get new pad material to seat on the new rotors.</TD></TR></TABLE>
will those Brembo blank rotors will work with the stock pads?
they are the lowest ive seen so far.</TD></TR></TABLE>
checked out the website...even though that rotors and pads say for 01-03 civic, I would think it is the same for 05?
Thx for everyone's help.
Old Oct 10, 2006 | 07:32 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ05se &raquo;</TD></TR><TR><TD CLASS="quote">will those Brembo blank rotors will work with the stock pads?</TD></TR></TABLE>
They will. But I would suggest upgrading the pads as well. They just go hand in hand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ05se &raquo;</TD></TR><TR><TD CLASS="quote">checked out the website...even though that rotors and pads say for 01-03 civic, I would think it is the same for 05?</TD></TR></TABLE>
They are the same. Unless you have the Hybrid sedan. They have a different part # for those.
When I bought my Hawk pads, they showed the same part #'s (HB-275) for the 01-05's. SO you will just need to find it for your year, and you are good to go.
Old Oct 10, 2006 | 10:48 AM
03EM2guy's Avatar
if i kept my stock rotors and went with the next step up from OEM for pads like semi metallic or somthin like that then could i tell a difference?
Old Oct 10, 2006 | 12:18 PM
oddmut's Avatar
I upgraded my rotors to Rotora slotted and cross drilled plus AEM brake pads. I love the feel. It feels way better than stock. My rotors are OEM size.
Also I had a friend who worked in this garage around where I live and he saw the owner of Rotora buying stock OEM rotors from a regular garage... Now that gets me thinking about rotora. lol Best bet is go slotted or go big brake kits slotted and cross drilled.
akkord94
Suspension & Brakes
Aug 6, 2008 09:22 PM
CivicSD
Feb 20, 2008 04:03 PM
R249
Apr 18, 2005 11:10 AM
PetroGuyX
Sep 30, 2003 06:51 AM
bigrob119
Nov 7, 2001 10:07 AM
