sputtering and jerking problems
when my car is at idle it is fine but when i shift it to first and try to drive off it starts sputtering and jerking it feel like as if u take a normal working car and try to drive it on 3rd gear on a full stop...it vibrates hard and wants to choke any suggestions? thanks
my car has the same problem, its a d16y7 turboed with just a fmu. ran fine until i punched it in 2nd then it started doing the sputtering and jerking thing when i start off. anyone know?
well i dont have either o2 sensor in, they were to hard to get out and i was tired. i just finished the car last night. i have a 96 civic hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmekrobot »</TD></TR><TR><TD CLASS="quote">well i dont have either o2 sensor in, they were to hard to get out and i was tired. i just finished the car last night. i have a 96 civic hatch.</TD></TR></TABLE>
That could very well be your problem. Put the O2 sensor in and see if that helps.
make sure that your spark plug wires are right and that your running good fuel. also try cleaning the intake pipe and the throttle body. my b16 started doing that and i cleaned it out and it runs fine now. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">
That could very well be your problem. </TD></TR></TABLE>
Wrong forum dude.
Wrong forum dude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAYgasDC2 »</TD></TR><TR><TD CLASS="quote">when my car is at idle it is fine but when i shift it to first and try to drive off it starts sputtering and jerking it feel like as if u take a normal working car and try to drive it on 3rd gear on a full stop...it vibrates hard and wants to choke any suggestions? thanks</TD></TR></TABLE>
Does this continue on up the rev range? Or does it go away after a few 1000 rpms?
i had the same problem with my ef one day the car just started jerking like it was going to fast to shut off but it felt like it was stil trying to and all i had to do was put new plugs in and check all ur grounds.... goodluck
Tater_321
Jul 14, 2008 10:36 AM
buzlink
Apr 2, 2006 04:01 PM
nwin
Jan 24, 2006 07:44 AM
5lugcivic
Apr 7, 2005 10:25 PM
