Suspension & Brakes Theory, alignment, spring rates....
springs or coilovers?
Old Oct 9, 2006 | 04:08 PM
TANGO28's Avatar
Default springs or coilovers?
sup fellas ima need some advice im getting an eg6 hatchback and right now its sitting on h&r springs. it rides smooth i think the owner cut the spring so ima need to get new suspension witch would be better springs or coilovers?
please help thanx.......
Old Oct 9, 2006 | 04:15 PM
Tyson's Avatar
Default Re: springs or coilovers? (HondaGuy28)
Should I get coilovers or springs?
Short answer:
If you're asking this question, you probably dont need "coilovers" and will be wasting your money and should buy a good set of Eibach Pro-kits or any other quality kit.
http://www.norcalcrx.org/tyson/coilover.html
Old Oct 9, 2006 | 04:17 PM
RSX-R's Avatar
COILOVERS because that way you can tune and adjust how stiff you want the dampers to be. and it will also be a better investment.
Old Oct 9, 2006 | 04:19 PM
TANGO28's Avatar
Default Re: springs or coilovers? (Tyson)
hey thanks guys............................
Old Oct 10, 2006 | 09:46 AM
nonsense's Avatar
Default Re: springs or coilovers? (RSX-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSX-R &raquo;</TD></TR><TR><TD CLASS="quote"> COILOVERS because that way you can tune and adjust how stiff you want the dampers to be. and it will also be a better investment.</TD></TR></TABLE>
what does that have to do with it being a coilover? Damper adjustment is independent of whether or not it's a coilover. For example AGX or Koni Sport with Eibach pro-kits is adjustable. Omnipower coilovers are not. The only advantage to getting coilovers is that they are ride height adjustable, allow changes to spring rates, and can be corner weighted. Most people don't need any of those on a street driven car.
I'd suggest the OP goes with a good shock and spring combo. I'm fond of Pro-Kit and Koni.
Old Oct 10, 2006 | 10:14 AM
future62
Guest
Posts: n/a
Yup, it'll made tyt3 w/the 128 levels of dampening control...
Seriously...coilovers and Illuminas...or some legit springs and Konis
yobbr5
Honda Civic (2006 - 2015)
12
Oct 24, 2007 01:43 PM
vpower
Mar 25, 2006 03:59 PM
ace0fspades
Suspension & Brakes
Dec 10, 2005 12:39 PM
Turbo-GSR1287
Feb 3, 2005 04:31 PM
DRxCIVIC
11
Apr 22, 2002 09:33 PM
