exhaust question
Old Oct 9, 2006 | 03:19 PM
joethejoeman's Avatar
Default exhaust question
I was wondering if more power would be gained if I just ran a header and nothing else?
Old Oct 9, 2006 | 03:37 PM
89 civic si's Avatar
Default Re: exhaust question (joethejoeman)
you might lose some power due to the motor not having enough backpressure, and it will be loud as hell take off your exhaust and try it
Old Oct 9, 2006 | 03:48 PM
rayzian's Avatar
Default Re: exhaust question (89 civic si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si &raquo;</TD></TR><TR><TD CLASS="quote">you might lose some power due to the motor not having enough backpressure, and it will be loud as hell take off your exhaust and try it </TD></TR></TABLE>
needing backpressure = myth
You'll loose low end power but gain in the top end thanks to all the added flow. I wouldn't suggest open header though (it's WAYYY too loud), you could try open exhaust though (no axleback) so atleast you're running a resonator (similar to having a buddy club spec II exhaust lol)
Old Oct 9, 2006 | 03:56 PM
Default Re: exhaust question (rayzian)
What do you mean by Axle back? and do would the CAT Conv. effect any thing if i take that off too?
Old Oct 9, 2006 | 04:00 PM
backpressure is by far not a myth the reason he would lose low end torque is because of loosing backpressure. why else would it be slower in the low end? take off the header and run the car like that and see what happens, tell me if backpressure doesnt matter..dont disagree just to disagree jeezzzzz
Old Oct 9, 2006 | 04:04 PM
Old Oct 9, 2006 | 04:09 PM
If i have a lot of back pressure, would it make more power?
Old Oct 9, 2006 | 04:20 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">If i have a lot of back pressure, would it make more power?</TD></TR></TABLE>
yes if you have more backpressure you will have double the horsepower try sticking a potato in your tail pipe and check out that mad v-tak
Old Oct 9, 2006 | 04:21 PM
if you want to have a happy medium i would just get a good exhaust like a whole system with a high flow cat and performance muffler there are many good choices
yaleforizzle
Jun 27, 2004 08:02 PM
es_squared
Apr 6, 2004 02:43 AM
slp mode
Dec 19, 2003 04:12 AM
Shingoblade-GSR
Jul 30, 2002 03:48 PM
