Omni Master Cylinder "clutch"
ive got a omni master cylinder for my clutch, i bought it brand new but managed to strip the threads where the line connects to it under the hood, i already have a replacement for it but figured maybe some-1 here could/would re-tap it or fix it and be able to use it'
its the newer version so no issues, ive got 5k+ on mine and it works great, clutch enguagement is very short, power gets to the ground much quicker then before and makes the stock clutch grab hard and quickly.....also helps reduce grinding sense it flows more and faster'
i guess like $20+shipping would be fine sense it does need to be repaired if you have the skills to do it'......the mc entry point for the line was stripped during install so it has 0 miles on it'....
vi3tromanc3r
Mar 9, 2007 12:56 PM
