Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
help with fog lights!
Old Oct 9, 2006 | 11:27 AM
honda06si's Avatar
Default help with fog lights!
i bought a fog light kit and am in the process of wiring it and on the inside of the car there is a white connector with a single red wire running into it but there is nowhere to plug it up at. i already plugged a gray connector into the fuse box and a brown connector into the brown connector that is already on the car and im left with this one connector unplugged and the fogs wont come on
i got these on ebay
Old Oct 9, 2006 | 12:16 PM
honda06si's Avatar
Default Re: help with fog lights! (honda06si)
ok people
there is 2 harneses with the kit. one of them has two connectors that plug into the bulbs of the fogs, and one connector that plugs into the brown plug that was already on the car thats behind the washer resivior and a ground wire.
the other harness has a green plug that goes into the on off switch, it has a gray connector with one wire, a white connector with one red wire, a brown connector, a fuse, a relay and a ground wire.
the gray connector seems to fit when i plug it straight into the fuse box, there is a big opening. the brown connector plugs into the brown connector inside the car that was there from factory.
i put a fuse in the place it says to in the fuse box
now all i have is the white connector.
on the write up ive seen it says you have to take a 24pin connector off the car and plug in 2 bare wires from the harness that came with the fog lights but this harness didnt have those
Old Oct 9, 2006 | 12:48 PM
honda06si's Avatar
anyone
00EckoSI
18
Aug 4, 2010 06:33 PM
Ef8crxsi4u2nv
19
May 13, 2010 01:55 PM
crist488
Lighting
Jan 8, 2010 09:55 AM
DOMAN!EJ8
16
Sep 2, 2009 10:17 PM
ShakesTheKlown
Mar 29, 2004 09:19 AM
