green stuff under the hood??
hello,
i was wondering i believe under the engine - where the 4 cylinders are i have a lot of green stuff...i used backing soda and water to clean it before, but it came back again...i have a small crack also there..i am wondering should i get it checked out?? i think its where the oxygen part is on the car (under the cylinders)
That triangle (V-shaped, you stated) area, is on your heatshield for your exhaust manifold (aka. header). Your four cylinders are inside the engine, so I'm having a tough time trying to understand where you're having a leak.
Why don't you save the image you posted, and use MS Paint to put a circle around where you have a leak, and then post that on imageshack.us and drop us a link.
it looks like a thin type liquid. the last time i used baking soda and water it went away, however, it came back within days. is it corrision? should i get it checked? any other details?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaScott »</TD></TR><TR><TD CLASS="quote">it looks like a thin type liquid. the last time i used baking soda and water it went away, however, it came back within days. is it corrision? should i get it checked? any other details? </TD></TR></TABLE>
Does it smell somewhat like warm pancake syrup? Because that's the smell of coolant burning. Then I would agree with fventura03, and say your head is cracked or atleast you've got a leaking head gasket. Check your coolant level to see if it needs coolant, and take your car to get it inspected/repaired, because it's a decent size problem, that could ruin your engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaScott »</TD></TR><TR><TD CLASS="quote">ill get it checked tomorrow...do u know how much it will cost?</TD></TR></TABLE>
Rough estimate - anywhere from $100 to $500.
no green stuff here... i've owned my car for 3yrs...
that doesn't sound right. if you start hearing noises, then you KNOW something's wrong. right now you're at the stage where you still have time to fix it, when you hear noises, it probably means you'll need a new engine.
i dunno.
i dunno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaScott »</TD></TR><TR><TD CLASS="quote">i went to the maniac and he said it is a common problem with hondas. he said if it starts to make a loud noise you know to get it fized. sound ok?</TD></TR></TABLE>
No, it's not a common problem. A leaking headgasket, or a cracked head is a rather serious problem.
hi i went to another mechanic today and he said not to get it fixed until you hear a loud noise from the exhaust. i am not sure what to do, should i go to another mechanic to get it checked? i am worried it may cause engine probs?
*** also if there was a big prob with it, would a light come on in the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">How often does the green stuff appear? And if you can, ask the mechanic what specifically is wrong. Because, if they won't tell you, it sounds very suspicious.</TD></TR></TABLE>
Agreed. If they're not telling you what the problem is, either they don't know, or they know what will happen after prolonged driving and they want more of your money.
clean it up again, check on it a lot, like before/after you drive, see if you can see where it starts. that'd give you an idea of what it is, maybe its a nicked hose that's spraying the coolant onto the header (that'd be the perfect scenario, $5 fix)
ok i went to midas and they looked at it quickly and they said it will cause engine probs b/c it oxygen sensors will make black air or something clogging it up...eventually putting the engine light on...they said it will cost like $1200. forget that.the 2nd mechanic i went to said wait until exhaust is noisey than bring it in...i unno guys what should i do? pay the $1200?
