couple questions
1: where is the refill hole and the drain plug to do the tranny fluid in a 5spd?
2: For some reason the car will start on the first try for awhile, then 1 day it will decide it doesnt want to start at all. I have successfully started it with starter fluid but it hesitates and dies, usually takes a few tries this way but it will start and run again for awhile.....then one day it wont start, just turns over. Any ideaS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr »</TD></TR><TR><TD CLASS="quote">2: For some reason the car will start on the first try for awhile, then 1 day it will decide it doesnt want to start at all. I have successfully started it with starter fluid but it hesitates and dies, usually takes a few tries this way but it will start and run again for awhile.....then one day it wont start, just turns over. Any ideaS?</TD></TR></TABLE>
Ignition problems? Have u checked all the ignition components?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr »</TD></TR><TR><TD CLASS="quote">i have a hole on the top of the tranny that is just caped with a rubber plug, what is that hole for?</TD></TR></TABLE>
Which # Is It In The Diagram Below?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRDB8GSR »</TD></TR><TR><TD CLASS="quote">Here You Go The Drain Bolt Is #12 In The Diagram
Refill Would Be #11
Anyone Else Agree/Disagree?</TD></TR></TABLE>
#18 is the fill plug. #11 is the reverse idler gear shaft bolt.
Refill Would Be #11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loopedR6 »</TD></TR><TR><TD CLASS="quote">your no start is the Main Fuel Relay</TD></TR></TABLE>
sounds right. just resolder it and it will probably fire right up
Refill Would Be #11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray »</TD></TR><TR><TD CLASS="quote">
#18 is the fill plug. #11 is the reverse idler gear shaft bolt.</TD></TR></TABLE>
I agree that #12 is the drain and #18 is the fill.
Modified by Dogginator at 6:23 PM 10/10/2006
Refill Would Be #11
It could be the fuel pump relay. Can you hear it prime?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
I agree that #11 is the drain and #18 is the fill.</TD></TR></TABLE>
#12 is the drain.
#12 is the drain.
#12 is the drain.</TD></TR></TABLE>
You are indeed correct.
I mistyped.
I mistyped.
So this is they nice annoying version where you need a syringe style thing to put the fluid in.......might be worth just paying $65 to have the tranny flushed and refilled
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr »</TD></TR><TR><TD CLASS="quote">So this is they nice annoying version where you need a syringe style thing to put the fluid in.......might be worth just paying $65 to have the tranny flushed and refilled</TD></TR></TABLE>
or a funnel with a long enough hose on the end so you can position the funnel on a suspension piece
i had a similar problem on a bmw. use that starter fluid to check for vacume leaks. again though it was on a bmw. i've only had an integra for a day and a half.
so no flamers plz.
so no flamers plz.
loayo
11
Mar 12, 2012 12:49 PM
mister.wong
Sep 13, 2008 04:45 PM
krshultz
29
Apr 17, 2002 09:24 PM
