i have a dart block and want to use a baffled oil pan for rr/ ax.....
Old Oct 9, 2006 | 09:01 AM
Black R's Avatar
25 Year Member
Default i have a dart block and want to use a baffled oil pan for rr/ ax.....
Like the topic says... I have a dart talldeck that I'm building (the block is actually finished, just need a head to complete the motor).
DART seems to have taken their cast from an LS... well I've had the erl 5 bolt main girdle mated to it by jim justice, and assembled/ clearanced by Don Flores.
Now I'm trying to figure out what baffled oil pan to use...
My understanding is that they will mate up with an LS oil pan and pickup.
BUT I need baffles. I can get a baffled mugen pan for a good price, so I had considered going with one of those. Or is there a RELIABLE weld-in baffle set available these days? I'd like one with the lips protruding down a bit to direct oil back at the pickup.....
Old Oct 9, 2006 | 12:26 PM
inspyral's Avatar
Fastline makes baffles for most Honda pans. I think they're less than $20 and look pretty nice. You can check them out here:
http://www.fastlineperformance...e.htm
Old Oct 9, 2006 | 01:36 PM
Black R's Avatar
25 Year Member
i can't tell from the pics, but do the baffles on the fastline product have a lip protruding downwards to aim oil sloshing back toward the pickup?
iirc, you can use whatever oil pan you want with bseries, it's just that you must use the matching oil pickup?
Old Oct 9, 2006 | 03:03 PM
inspyral's Avatar
It looks like they're just flat plates from the pics. Yeah, I believe the pickup you're using dictates which pan to use.
b18psi
Mar 29, 2007 03:50 PM
KMk51188
Dec 15, 2006 02:38 AM
AZintegragsrT
Jun 30, 2006 01:26 AM
integraboosted
Mar 28, 2006 10:10 AM
Smooth_Imports
Sep 8, 2005 09:34 AM
