Passenger Door Beeping
Once the car is running, if you open the passenger door the car will beep non stop until I shut the car off and restart it. Where is the sensor at for this alarm on the door? its so damn annoying.
Look where the door latch is on the body. Now look down a little and you will see a slide switch. What I did was slide it in toward the inside of the car and wedge a little piece of rubber into it so it doesn't move.
You can also remove it and disconnect the wire from the switch and electrical tape it so it doesn't touch anything.
arrocha87
Jan 19, 2009 09:57 AM
I shoved a little metal piece in there for now ... when I get home from work ill probably take it off.
