HELP! fucking sunroof
Old Oct 9, 2006 | 08:35 AM
haroldthefly91crx's Avatar
Default HELP! ******* sunroof
my damn sunroof is busted, it wont close and i have been putting off replacing it for a while, then it rained last night. i have tried to fix it but it is all busted inside.
my question is, will a civic of the same generation of my crx with a sunroof fit mine?
Old Oct 9, 2006 | 08:39 AM
HondaFerris's Avatar
Default Re: HELP! ******* sunroof (haroldthefly91crx)
no, the crx and civic sunroofs are different.
Old Oct 9, 2006 | 09:10 AM
Loserkidwac's Avatar
Default Re: HELP! ******* sunroof (HondaFerris)
see that little plastic plug in the roof you should be able to pull that out and use a tool to hand crank the sun roof open or closed...aslo have you take the switch apart and cleaned the contacts? the CRX I just bough would only open to ven and not slide once i removed and clean the switch it works better than any other car I've seen, hope that helps and yea CRX Sunroof only fits...
Old Oct 9, 2006 | 09:50 AM
Default Re: HELP! ******* sunroof (Loserkidwac)
the tracks are rusted and so are the cables and some of the linkage is broken so t wont seal, so its fucked, i need a new one
Old Oct 9, 2006 | 09:59 AM
ludesrv's Avatar
Civic = Moonroof
CRX = Sunroof.
You are out of luck there.
Simply visit your local scrap yard and see what they have. Go ask honda what they have too.
B16CRXVTEC
Oct 14, 2010 08:35 AM
doom26464
Aug 5, 2008 08:36 PM
tractionless
Apr 28, 2006 03:54 PM
Jonathan_ED3
Aug 28, 2004 11:18 PM
94gsrhatch
May 11, 2004 07:58 AM
