14in drag radials
I'm looking at two sets of tires.
205/55 14 Nitto 555
205/50 14 BFGoodrich drag radial.
Anyone know which tire would be better and what Air pressure I should run the tires at?
My last option is a 20X8.0 14
but I'm looking at that as a last resort because I think it would be smaller then the two drag radials. I'm going to run these on a separate set of rims so they won't be driven on the street just at the drag strip.
205/55 14 Nitto 555
If this is drag strip only I would say that you should use the full slicks, drag radials are more something you would use on the street, or at least thats were I use mine. If you really want to go with the drag radials, then go with the BFG's, they do an excellent job.
yea its for Drag only. I can get teh tires through my job so I was looking for which size would work the best and get teh best traction.
