Steering wheel shakes when braking...pls help
Old Oct 9, 2006 | 05:18 AM
Skiefer's Avatar
Default Steering wheel shakes when braking...pls help
When I push the brake down to slow down I can feel the steering wheel shaking pretty hard and the car shakes a bit when slowing down. What would cause this my ABS light has been on since I have had the car but the seller said it was just a faulty sensor or something. I dunno... But I am concerned about the shaking, can someone please gimme some advice, Thanks!
Old Oct 9, 2006 | 05:47 AM
Duane_in_Japan's Avatar
Default Re: Steering wheel shakes when braking...pls help (Skiefer)
replace the front rotors, dont machine them. The two wheels may be spinning at just enough of an uneven rate to set the ABS light, fix the shaking and I bet the light will stay out.
Old Oct 9, 2006 | 05:48 AM
Miracle's Avatar
Vibration on braking: Usually a warped rotor, or tire out of balance. Rotors need to be turned or replaced.
ABS light on: Check your fluid level in the master cylinder. That is usually the problem %90 of the time.
Old Oct 9, 2006 | 07:21 AM
jamoore115's Avatar
my 93 accord does the same thing and i just put new brakes on but i think the rotors were bad and thats eating down the pads..not to mention my alinment might be out too. goin 130 down the interstate and hitting the brake while the cars shaking ..lol..not good..i want a smooth brakinking
Old Oct 9, 2006 | 08:35 AM
lunarone's Avatar
Default Re: (jamoore115)
in america, we use MPH, not KPH, jamoore115!
Old Oct 9, 2006 | 01:33 PM
Default Re: (lunarone)
jamoore115, I think lanarone is calling you out.
Old Oct 9, 2006 | 05:39 PM
cambopheonix56's Avatar
Default Re: (Duane_in_Japan)
Usually a warped rotor.
20-EM2-05
Acura TSX
Aug 4, 2009 07:39 PM
arinaldi
Jun 24, 2009 08:47 PM
iNexus
Apr 5, 2008 04:40 PM
