WTB: OEM JDM GSR or Type-R header w/ Heat shield.
JDM ITR header with the upper and lower OEM heatshields, and 2.5 inch Carsound cat for sale. Header and cat were installed at the same time, used for 4 years/37K miles. These parts have never been touched by road salt.
The silver areas you see are what's left of the high temp paint I had put on. I guess I didn't prep the surface correctly, because it flaked off quite a bit, but it really cooked on there pretty well in some spots. I sanded the whole thing down with some 150 grit, so what you see left on it won't come off without some harder sanding. It's done flaking though. I just wanted to sand it down enough so it would no longer flake.
The upper heatshield is is really nice condition. Not mint, but close. The lower heatshield is coated with the same high temp paint I had painted the header with, it didn't flake at all, it looks good.
Here's some shots with the heatshields on:
You can see the heatshield covers up the header pretty well. The header flange didn't flake at all, I guess because it's grittier and held the paint better than the smoother pipe surface could. So it still looks good in the car.
Here's the carsound cat:
Not the greatest pic, but its the only one I have of it right now.
It just passed a N.H. inspection in August.
This header and cat combo together end at the factory b pipe location, so it will fit into and Teg with an OEM or aftermarket catback system.
$300 for everything
I'm in central N.H., where do you live? I see your not asking for a cat also, but I want to sell them as a pair because this cat will be hard for me to sell by itself. So I thought I'd throw this package offer to you.
$300 for everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allm0torGSR »</TD></TR><TR><TD CLASS="quote">JDM ITR header with the upper and lower OEM heatshields, and 2.5 inch Carsound cat for sale. Header and cat were installed at the same time, used for 4 years/37K miles. These parts have never been touched by road salt.
$300 for everything
I'm in central N.H., where do you live? I see your not asking for a cat also, but I want to sell them as a pair because this cat will be hard for me to sell by itself. So I thought I'd throw this package offer to you.</TD></TR></TABLE>
damn, i wasnt really looking to spend that much. i really dont need a cat tho, im useing a test pipe so i have no use for it. lemme know if we can work soemhting out.
$300 for everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LUXXXX »</TD></TR><TR><TD CLASS="quote">http://hondamarketplace.com/zerothread?id=1753541</TD></TR></TABLE>
thanks for the reply doode, but i only have $200 GL with your sale.
