Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
headlights
Old Oct 8, 2006 | 04:59 PM
Nozidjr's Avatar
Default headlights
if anyone can help me, i just need to kno where i can buy the black housing jdm headlights for the EM2.
Old Oct 8, 2006 | 05:04 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: headlights (Nozidjr)
simple anser: u cant.
u can make your exsisting ones into blacked out ones. just search.
Old Oct 8, 2006 | 05:06 PM
OSK Automotive's Avatar
http://cgi.ebay.com/ebaymotors...QrdZ1
There's more on ebay just look. No gurantee on what quality they are. FYI you could paint your stockers that's what I did.
Nozidjr's Avatar
Default Re: headlights (DieMaster)
alrite cool thanks for the help.
Old Oct 8, 2006 | 05:07 PM
Miracle's Avatar
Default Re: headlights (MisterFrankieJ)
Is it really that FREAKIN hard to look a little bit, or maybe even SEARCH for once???? It is not like there isn't an exact same thread on the first page or anything...
https://honda-tech.com/zerothread?id=1768396
And BTW, for the record, you can't get JDM headlights for our cars. Our cars were never on the Japanese market, so anything you get will be strictly USDM.
Old Oct 8, 2006 | 08:32 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nozidjr &raquo;</TD></TR><TR><TD CLASS="quote">if anyone can help me, i just need to kno where i can buy the black housing jdm headlights for the EM2.</TD></TR></TABLE>
1. Black housing headlights aren't JDM, they're aftermarket DIY jobs, or just plain eBay specials.
2. JDM headlamps aren't worth the dollars some people spend to get them. Just crack yours open and spray the chrome with some high heat black paint, if need be.
Old Oct 9, 2006 | 05:08 AM
Default Re: headlights (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote"> Is it really that FREAKIN hard to look a little bit, or maybe even SEARCH for once???? It is not like there isn't an exact same thread on the first page or anything...
And BTW, for the record, you can't get JDM headlights for our cars. Our cars were never on the Japanese market, so anything you get will be strictly USDM.</TD></TR></TABLE>
Hmm sedans were on the Japanese market.
Old Oct 9, 2006 | 07:45 AM
Sean DM's Avatar
honestly why waste the money on buying new ones?
the only thing i would do if i had to do would buy new stock ones that are perfect off ebay and then use those for the black housings
what i did was
i took a torch and went around the plastic really slowly with it on low so the sealent would get gooey then i just took a flat head screw driver and pryed it apart and then once i had enough room to put my fingers in there i pulled it all the way apart.
and then you simply undo the screws and carefully pull out the chrome housings
then you can paint them what ever color u want.
i used about 2 layers of paint and 1 clear coat and it seems to be doing good with no fading.
after that just put the head light assembly back to gether carefully and use silicon or some other sealent around the edges and press it together..
don't forget to use the clips that came off the lights or you will have leaks
Old Oct 9, 2006 | 12:59 PM
toyomatt84's Avatar
Sanji
Default Re: headlights (Sean DM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean DM &raquo;</TD></TR><TR><TD CLASS="quote">honestly why waste the money on buying new ones?
what i did was
don't forget to use the clips that came off the lights or you will have leaks</TD></TR></TABLE>
It's safer to just put the headlights in your oven at 185deg. for about 5min. to get the sealant to budge.
Old Oct 9, 2006 | 02:26 PM
Nozidjr's Avatar
Default Re: headlights (toyomatt84)
nice. thanks for all the help you guys!
Old Oct 9, 2006 | 05:49 PM
Boost_Junkie's Avatar
theyre super expensive to buy...diy for $5 and some free time
01_ITR
Dec 2, 2008 07:55 PM
Namdaman
Feb 14, 2005 09:41 PM
GregblkEx04
Feb 12, 2005 09:28 AM
chwmeinthg
Feb 11, 2003 03:44 PM
