Keyless Entry
I have a base fit and am looking at buying the keyless entry add on kit from http://www.handaaccessories.com and then buying a key with the remote attached. Would it be possible to get the 06-07 accord key/remote combo programmed and cut to work with my fit?
no, it would not be possible to use a Accord key, they use a different frequecy then the FiT, and i believe the FiT keyless accessory is just a ramote, not a remote key like teh sport, but i'll look into that more when i go into work today.
yeah the fit key is a remote key i just unwrapped one yesterday i love that slap shift. if you want the accord key for the trunk opp. i dont think the fits will pop the trunk for you but i can check.
No, only the Sport model has a remote key, the base models get a regular remote, seperate from teh key, however i'm sure a Sport key could be used on a base, inwhich case would require keyless and alarm installation, since they are 2 different accessories from factory, meaning not the same kit.
Here is the first page from teh installation instructions of the keyless entry system, which if you look closely it's a remote, not a key, as i previously have stated, however again i'm sure you could use a sport key aslong it accept teh same frequency.
Also just to re-iterate, a Accord key can't be used since it have a different frequency, not even to start the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 »</TD></TR><TR><TD CLASS="quote">If you buy that kit for $108 from H and A it will have everything you need to install and program. I bought that kit for my base model Fit.
</TD></TR></TABLE>But keep in mind, that it's just keyless entry, the alarm is not in the same kit, they are 2 seperate kits.
friday
Nov 14, 2004 10:55 PM
