F/S 1989 CRX Si and some B-Series parts BEST OFFER
Alright, my parents have complained (once again) at how much stuff I've got lying around, so I figured I'd put this stuff on here before I send it to the garbage...
-- 89 CRX Si full motor (tranny, block, head, oil pan, intake manifold, distributor, valve cover, alternator, most of the mounts) I pulled this from my CRX the day I got it. Motor didn't run, I didn't look into why, I just pulled it out of there and now it's sitting on my porch half taken apart...
-- 89 CRX Si throttle cable
-- B18A motor mounts
-- B18A intake manifold (just bare intake manifold)
-- B18A engine block with some problems (on the cylinder wall there are small chips taken out of the wall on the outside where the coolant is, don't know why or what happened, I was sold this lovely piece of garbage and when I took it apart it was messed up)
-- B18A Cylinder head (most likely trash, there's not much you can use except maybe the exhaust camshaft, or maybe the cams themselves)
-- B18A Oil pan (Looks like the drain plug is stripped, and it def. needs a good cleaning inside)
-- B18A stock flywheel
Everything is for whatever price you want to offer me, I'm not really asking for anything. I figured if anybody needed anything I'd put it on here and give it to you guys before the dumpster. Local pickup only, located 15 min. from Allentown
PM me if you need any of it...
JDM RHD eg6
Jan 21, 2005 07:08 PM
