Help with climate control reinstallation.
Old Oct 8, 2006 | 02:47 PM
Wayne_Curr's Avatar
Default Help with climate control reinstallation.
I did my tan-black dash swap yesterday and so far the only bug i've got to work out is the climate control. I'm thinking I didn't route the cable (temperature adjustment) properly or didn't secure it properly or something because its just not working. I read through the team-integra.net article on it and searched HT and cant find anything. Can someone explain specifically how to properly route this cable so it works?
TIA
Old Oct 8, 2006 | 02:54 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Help with climate control reinstallation. (Wayne_Curr)
i need to know this too, so if anyone can provide pics that would be awesome, i put in the CF ITR climate control and forgot how the cable went when i took out my stock one, now it doesnt work
Old Oct 8, 2006 | 03:07 PM
LaterApex's Avatar
Is there a way of posting pictures here without an iServe subscription?
Old Oct 8, 2006 | 03:11 PM
Guess whos bizzack
Default Re: (LaterApex)
yes use any photohosting site(photobucket, we-todd-did-racing)
Old Oct 8, 2006 | 05:37 PM
Wayne_Curr's Avatar
Default Re: (It's*BOLO!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">i need to know this too, so if anyone can provide pics that would be awesome, i put in the CF ITR climate control and forgot how the cable went when i took out my stock one, now it doesnt work </TD></TR></TABLE>
I figured it out dude. Took off the climate control again today and found where to make sure the cable is mounted on the CC itself. Then you route it through a little channel down to the heater core. However, when i was trying to get the cable mounted to the CC and the lever, the plastic switch broke off the metal bracket. Old plastics FTL
CF CC here I come I guess =P
Old Oct 8, 2006 | 05:39 PM
Guess whos bizzack
Default Re: (Wayne_Curr)
my problem is knowing where to run it down from the CC itself to the thing it connects to, theres a couple different paths to take, i need a pic of how it goes
Old Oct 8, 2006 | 05:43 PM
gsr dood's Avatar
i got the ssame prob someone post a pic with the correct direction for the wire. the slider is mad hard to push and only moves an inch either way.
Old Oct 8, 2006 | 05:46 PM
Guess whos bizzack
Default Re: (gsr dood)
haha exactly, i hate it
Old Oct 9, 2006 | 11:28 AM
Wayne_Curr's Avatar
I'm going to bump this to see if anyone will take pictures of how to route this right =P
I think i know but I cant test it since I broke the lever off my CC.
Old Oct 9, 2006 | 11:29 AM
Guess whos bizzack
YES!!
Old Oct 9, 2006 | 11:45 AM
-Todd-'s Avatar
haha I had the same problem when I removed my climate control... took me forever to find the correct route for the line.
Old Oct 9, 2006 | 11:58 AM
Guess whos bizzack
Default Re: (-Todd-)
well pics FTW!!
Old Oct 9, 2006 | 09:49 PM
Wayne_Curr's Avatar
Last time and I give up =P
Old Oct 10, 2006 | 06:26 AM
Guess whos bizzack
come on somebody get a pic
Old Oct 10, 2006 | 07:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
well I never had a problem removing mine or putting it back in (when changing bulbs, or removing the dashboard). But I can't remember exactly how it's routed from memory, sorry.
Old Oct 10, 2006 | 07:52 AM
Baron55's Avatar
i did it before, but dont exactly remember how i did it. It took a few tried to get it right because it wouldnt move all the way right...I just kept trying. Try and push it as far in as you can, pull the heater switch fully toward you and hook it there, but make sure you set it to warm side fully on the climate conrtol unit and connect them both...Put it in place and see if it moves all the way left and right, if so good to go
Old Oct 10, 2006 | 11:09 AM
CHONCH2's Avatar
make sure the cable didnt disconnect itself from the valve outside of the cabin, on the firewall
Old Oct 10, 2006 | 11:55 AM
Wayne_Curr's Avatar
Default Re: (CHONCH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHONCH2 &raquo;</TD></TR><TR><TD CLASS="quote">make sure the cable didnt disconnect itself from the valve outside of the cabin, on the firewall</TD></TR></TABLE>
Wha?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">i did it before, but dont exactly remember how i did it. It took a few tried to get it right because it wouldnt move all the way right...I just kept trying. Try and push it as far in as you can, pull the heater switch fully toward you and hook it there, but make sure you set it to warm side fully on the climate conrtol unit and connect them both...Put it in place and see if it moves all the way left and right, if so good to go</TD></TR></TABLE>
I guess its just going to be a trial and error venture =P
1991hb
Aug 12, 2009 02:16 PM
DOHCter VTEC
Jan 21, 2008 09:03 PM
Mr.Integra
Sep 6, 2003 12:58 PM
