How to take apart my dash and guage cluster? 5th Gen
Old Oct 8, 2006 | 01:59 PM
m1ndless's Avatar
* B A N N E D *
Default How to take apart my dash and guage cluster? 5th Gen
I want to take off my dash, so I can do a LED swap, but I am not sure how to do this correctly. Is there a diagram or tutorial that would show how to do this correctly?
Old Oct 8, 2006 | 02:26 PM
twistedframe512's Avatar
pop out the switches (ie cruise control. defrost, and blinkers) behind each of these switches will be a philips heaqd srew that you need to romove. Then there are two more screws in front of the gauge cluster on top. If you remove all of these screws you should be able to pull the black dash piece out. You will have to unplug the plugs that go ti the climate control as well as remove the cable that goes to the fan adjustemnt.
Old Oct 8, 2006 | 06:43 PM
m1ndless's Avatar
* B A N N E D *
Default Re: (twistedframe512)
How do I pop out the switches?! Pop out the blinker?
Old Oct 8, 2006 | 07:01 PM
gianinline's Avatar
There is a little gap on these switches when you look close, all you need to do is put a screwdriver (flat head) and pry them out. Be sure to use a piece of cloth or something below the switch and under the screwdriver, so you avoid damaging the panel.
Old Oct 8, 2006 | 07:08 PM
gianinline's Avatar
Default Re: How to take apart my dash and guage cluster? 5th Gen (m1ndless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ndless &raquo;</TD></TR><TR><TD CLASS="quote">I want to take off my dash, so I can do a LED swap, but I am not sure how to do this correctly. Is there a diagram or tutorial that would show how to do this correctly?</TD></TR></TABLE>
Well, I just did a search and didn't find anything that actually had pics.
But I remember when I did mine, and it was with the help of 94-97 Accord manual from Haines.
It would be better using the Haines manual, because it show pictures step by step.
redsidriver
Feb 13, 2007 11:42 AM
Backk InTheDA
Mar 17, 2005 10:03 AM
HKSpowers
Nov 10, 2003 05:24 AM
jamal-188
Aug 4, 2003 05:35 PM
