Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
FAQ: My radio says CODE on it. What do I do?
Old Oct 8, 2006 | 12:59 PM
Miracle's Avatar
Default FAQ: My radio says CODE on it... What do I do?
If you have ever disconnected your battery, you will have the word CODE show up on your OEM radio. If you are not the original owner, or even if you are, you may not have the card that came in the owners packet that has the 5 digit code on it. If you do not know what an owners manual packet is, it includesthe following: A service history guide, warranties booklet, a quick start mini owners manual, an owners manual, a tire warranty guide, the radio code and serial number card, and a tire care guide.
When the radio says CODE on it, it is asking you for the 5 digit code on that little white card in the owners manual packet.
Use the "PRESET" station buttons, enter the code, one digit at a time.
If for some reason you do not have that card, you will need to pull the radio out of the dash, and obtain the serial number from the back of it. Then, call your dealership, and they should provide you with the code for your radio.If not, keep calling Honda and Acura dealers until you can find someone that can help. They may require you to come in, maybe with the radio in hand, to obtain the code.
Modified by .Red.EM2 at 9:42 PM 11/7/2006
Old Oct 8, 2006 | 04:56 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: FAQ: My radio says CODE on it... What do I do? (.Red.EM2)
can i get those books for a 2002?
this should go in FAQ
Old Oct 8, 2006 | 05:05 PM
Miracle's Avatar
Default Re: FAQ: My radio says CODE on it... What do I do? (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">can i get those books for a 2002?
this should go in FAQ </TD></TR></TABLE>
A dealership should have them, or look on eBay. And I have already PM'd Todd asking for the FAQ status in the main thread.
Old Nov 7, 2006 | 06:39 PM
IceAeon's Avatar
Actually, here is a trick you can use to obtain the serial number of your OEM radio easily (so you DO NOT have to pull it out of the dash)
Turn your radio off. Hold down the preset button #1 & #6. While holding these buttons down, turn your radio on.
The serial number will be displayed on the LCD in a scrolling fashion, and constantly repeat itself.
So take a pen and paper and write it down as it scrolls by.
This works on my 2002 Honda Civic EX, and many other models.
ALSO:
Sometimes the serial number is located on a white sticker located on the inside or under-side of your glove box. Another spot, is a white sticker possibly on the passenger door frame when the car door is held open.
With this number, you can just call your local Honda dealer and give them the serial number and they can read you the code for your radio. Make sure to write it down for future use.
Old Dec 27, 2006 | 10:55 AM
samanthaw's Avatar
Default Re: (IceAeon)
i disconnected my battery yesterday and had to figure out my radio code - when i called the dealership the guy said to look for a white sticker on the glove box, sun visor, cupholders, center console (or anywhere else you can think of where there might be a sticker).
mine was in the glove box. (i have an 03 civic lx.)
if you find the white sticker, the five digit number on it is your radio code.
Old Dec 29, 2006 | 05:27 PM
latindc2's Avatar
i just got a 01 civic...and i need to know how to adjust the time?
Old Jun 7, 2007 | 07:33 PM
alexdovnj's Avatar
i tried what u suggest it didn't work i have a civic 01 coupe ex ,what else can i do in order to get the damn radio on ?
Old Jun 8, 2007 | 09:53 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (alexdovnj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdovnj &raquo;</TD></TR><TR><TD CLASS="quote">i tried what u suggest it didn't work i have a civic 01 coupe ex ,what else can i do in order to get the damn radio on ?</TD></TR></TABLE>
Holy crap, 1st post and a search!
Old Jun 8, 2007 | 11:40 PM
i-VTEC_DOHC's Avatar
Default Re: FAQ: My radio says CODE on it... What do I do? (Miracle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle &raquo;</TD></TR><TR><TD CLASS="quote">If you have ever disconnected your battery, you will have the word CODE show up on your OEM radio. If you are not the original owner, or even if you are, you may not have the card that came in the owners packet that has the 5 digit code on it. If you do not know what an owners manual packet is, it includesthe following: A service history guide, warranties booklet, a quick start mini owners manual, an owners manual, a tire warranty guide, the radio code and serial number card, and a tire care guide.
Modified by .Red.EM2 at 9:42 PM 11/7/2006</TD></TR></TABLE>
well u can just take out ur radio and look on the bottom or top of it and the code is on it
Old Jun 9, 2007 | 02:43 PM
toyomatt84's Avatar
Sanji
Default Re: FAQ: My radio says CODE on it... What do I do? (i-VTEC_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">
well u can just take out ur radio and look on the bottom or top of it and the code is on it</TD></TR></TABLE>
Actually, that's the serial number. It can be used to get the Unlock Code, but it isn't the code itself.
Old Oct 4, 2007 | 07:27 AM
ali311's Avatar
Hello army guy...
I just bought a second hand civic 2005... and of course the radio is lock (anti-theft mode)..... and it didn't come with the owners manual booklet :S even not with the spare tire.
i have searched the freaking code on the net and can't find it.
Can you provide me your radio code? just in case who knows would work on mine please!.
I tried with the '22123' code from an Acura 2005 but didn't work.
Old Oct 4, 2007 | 08:13 AM
daddy's Avatar
Default Re: FAQ: My radio says CODE on it... What do I do? (ali311)
you should be able ot get it from a dealer. i believe they need ur vin number. possibly the serial number off the stereo itself
Old Oct 4, 2007 | 08:50 AM
wickedbautista's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ali311 &raquo;</TD></TR><TR><TD CLASS="quote">Hello army guy...
Hey i'll share my radio code 36433 hope it helps
Old Jul 13, 2008 | 04:20 PM
citystreetsbimmer's Avatar
Default dead radio + keyless entry
2002 civic seadan. the battery died so it was replaced with a new one. after the fact everything works but the radio and the keyless entry.i have the code for the radio but it wont light up for me to even type it in.
Old Jul 18, 2008 | 02:33 PM
mexxem2's Avatar
Default Re: FAQ: My radio says CODE on it... What do I do? (wickedbautista)
correct me if im wrong but i believe every radio code is different for every car...
I had this same problem and got annoyed with it so I just bought a pioneer deck.
shows how lazy i am hehe..
Old Jul 25, 2008 | 12:32 PM
88bstdteg's Avatar
the dealer will also hide the code either in the glove compartment, under lid of fuse box in engine compartment or between the rear speakers in the trunk, it will be a 5-6 digit code depending on your model, the dirrections to enter the code is in your manual
Old Jul 25, 2008 | 02:23 PM
SE-Rious's Avatar
It's actually ALOT easier than calling or even going into the dealer.
It can all be done online now:
https://radio-navicode.honda.com/
You're welcome
Old Jul 28, 2008 | 08:48 AM
FuriousYellowSi's Avatar
I just had to give my dealership my VIN number and they had my code looked up in minutes
Old Jul 29, 2008 | 05:03 AM
scrooge's Avatar
Default Re: (FuriousYellowSi)
it worked i love you no homo lol
Old Jul 30, 2008 | 06:59 PM
Limestand's Avatar
The code for your radio is always listed in your fuse box under the hood.
Old Jul 30, 2008 | 08:17 PM
toyomatt84's Avatar
Sanji
Default Re: FAQ: My radio says CODE on it... What do I do? (Limestand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Limestand &raquo;</TD></TR><TR><TD CLASS="quote">The code for your radio is always listed in your fuse box under the hood.</TD></TR></TABLE>
No it isn't.
Old Sep 26, 2008 | 01:32 PM
heylovie's Avatar
Default Re: (samanthaw)
Also, for a 2001 Civic EX the sticker is in the trunk, up by the back speakers, behind the metal wire that I think is the trunk release.
Old Sep 26, 2008 | 09:36 PM
toyomatt84's Avatar
Sanji
Default Re: (heylovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heylovie &raquo;</TD></TR><TR><TD CLASS="quote">Also, for a 2001 Civic EX the sticker is in the trunk, up by the back speakers, behind the metal wire that I think is the trunk release.</TD></TR></TABLE>
Not always, it isn't. Mine is on the outside of the glovebox.
Old Sep 27, 2008 | 06:09 PM
_illmatic_'s Avatar
Default Re: (toyomatt84)
Mine is located inside the glove box. 04 LX coupe.
Old Oct 19, 2008 | 02:27 PM
EM2_08's Avatar
Default Re: (loski)
read the top
