? about the FITV ?
Old Oct 8, 2006 | 12:13 PM
superhatchbackbros's Avatar
Default ? about the FITV ?
i just cleaned the FITV and it still has suction at idel which makes my car surge high, neways i heard that on the z6 tb u can plug up the fitv on the tb and bypass it. when i put my finger on it, idels mint at like 900-1000rpm. when i let off it surges high, to get to the point my question is can i block that with some rubber and bypass it, please someone hit me back.. thanks
Old Oct 8, 2006 | 12:18 PM
anybody? can someone help that knows..
UltimX's Avatar
Default Re: ? about the FITV ? (superhatchbackbros)
which car is it on? z6? if so, just use some honda bond around it to prevent the leak
Old Oct 8, 2006 | 12:27 PM
its a z6 tb and IM on a d16y7 motor, its having vacuum on start up so the idel surges high. it i block that hole car runs mint. i was wondering if anthing could get hurt if i block this off, i heard some people doing this????
Old Oct 8, 2006 | 02:03 PM
UltimX's Avatar
Default Re: (superhatchbackbros)
in all honesty, depending on where u are, it doesn't make a difference. its mainly for startup.
Old Oct 8, 2006 | 09:49 PM
i customly plugged it up with a peice of rubber, its at normal idel and im finaly happy with it..
Old Oct 9, 2006 | 03:04 AM
slywfbpsi's Avatar
you say you cleaned the fitv, but did you tighten it? https://honda-tech.com/zerothread?id=699787 Mine was idling high when I did my d15b swap. Tightened it and idle was normal
cityofcaterpillars
23
May 24, 2016 08:03 PM
goat86
13
Mar 24, 2014 02:32 AM
fallrivercolin
Apr 12, 2011 04:51 PM
4g4dcruisin
25
Jun 30, 2010 06:30 AM
TABIAS
Dec 1, 2003 04:23 PM
