how do i
Old Oct 8, 2006 | 10:59 AM
EF-Boy91's Avatar
Default how do i
how do I change the oil in my ys1 trans.... some one send me a diagram or summin
thankz
Old Oct 8, 2006 | 01:07 PM
Suck my DX's Avatar
Default Re: how do i (EF-Boy91)
drain it and fill it...if you really gotta ask this please take it to a lube shop like jiffy lube or EZlube
Old Oct 8, 2006 | 01:37 PM
h224thgensedan's Avatar
drain plug is on the bottom of the trans 3/8ths rachet works to loosen it and then the fill plug is in back of the trans by were the axles go in 17mm bolt
Old Oct 8, 2006 | 01:40 PM
EF-Boy91's Avatar
Default Re: (h224thgensedan)
thanks
i didnt know where the drain and fill were
Old Oct 8, 2006 | 03:43 PM
gator88's Avatar
drain is always at lowest part and fill is always at the highest part. but thats okay, i always ask dumb questions. BEFORE you drain your tranny fluid, make sure you take out your filler plug. If you drain all ur tranny fluid and then decide to strip or break the filler plug, ur **** Outta Luck!! and to get to the filler hole, a funnel and hose works great to snake down in there.
Old Oct 8, 2006 | 05:22 PM
EF-Boy91's Avatar
i was woundering if i should consider rebuilding my trans with s80 internals .. my ys1 is a jdm one from the xsi its got short gears and my stock b16 pulls real hard with it i was just woundering if this would be a good thought for down the road
niceprelude
10
Feb 8, 2009 04:20 PM
the_rex
11
Apr 9, 2008 05:26 PM
dork
Jul 9, 2004 02:01 PM
4doorLX
Oct 2, 2002 10:55 AM
96Prelord
Jun 5, 2002 07:21 PM
