ef9 front bumper mounting
i cant get this fu#@in bumper on. its a jdm ef9 bumper goin on to my 91 hatch.the stock bracket doest fit onto bumper (cover). is there something im missing here? do i have to get jdm bracket as well? i cut corners of bracket for turn signals as well.
ef9 is the civic hatch, take your stock us bumper cover and support off. get rid of em you wont need em, there should be two brackets in the ef9 bumper cover that should have two holes each that should somewhat line up with the two holes you just took the bolt out of. also make sure you have the headlight filler piece and headlight and so forth. it will fit you may have two loosen up the stock brackets on the car and let the adjust to the jdm bumper, it can be a pain but well worth it. ef8 is the crx not ef9. good luck and hope it works out and you get it to fit.
if your bumper has that metal bracket on the back of it on each side u have what you need. if not., not sure why u dont. good luck. but you should have those metal brackets and they should line up with your car.
4inspeed
Oct 30, 2003 11:41 AM
type_racerz
14
Dec 17, 2002 08:45 AM
Giuseppe
Jun 8, 2002 03:28 AM
