B16a question, Is it suppost to be alittle noisy, when at IDLE
When I am idling it is somewhat noisy as far as other cars like you can hear...
no rear panels, or seats...
trying to make it alittle less noisy...?
most of the mount kits are solid ,,so at idle it vibrates like crazy and is bassy..this more noticeable with some kits then others,but normal...what can you do? nothing really just wait a while eventually the mounts will break in more and loosen up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">most of the mount kits are solid ,,so at idle it vibrates like crazy and is bassy..this more noticeable with some kits then others,but normal...what can you do? nothing really just wait a while eventually the mounts will break in more and loosen up...</TD></TR></TABLE>
my car vibrates like effing mad when its at idle, like I cannot look out the rearview mirror because it is shaking violently. I have stock mounts. What could be the cause of that problem. The engine runs just fine, I was thinking it could be bad motor mount inserts or something, possibly those need to be replaced?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">my car vibrates like effing mad when its at idle, like I cannot look out the rearview mirror because it is shaking violently. I have stock mounts. What could be the cause of that problem. The engine runs just fine, I was thinking it could be bad motor mount inserts or something, possibly those need to be replaced?</TD></TR></TABLE>
What RPMs is it idling at? Low idle will shake like a ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian »</TD></TR><TR><TD CLASS="quote">What RPMs is it idling at? Low idle will shake like a ****.</TD></TR></TABLE>
sometimes warming up at 1300-1400 it will make the mirror shake like crazy, otherwise sometimes I get a little massage at like 850RPM-1000RPM
would love to know what the hell the problem is
check the rear mount,maybe its touching the body
when warming up its like at 1200 rpm and then when warmed up its goes from 600 to 900,
but I have a bad IACV so I cant really say ...
There is a guy on here, wesv, I think is his name. He built his own mount set using rubber bushings. Here is how he did it: http://www.performanceforum.co....html
He has alot of pretty cool stuff on there, and it doesn't look THAT hard.
-Chris
-Chris
I have after market solid mounts I knew it was going to noisy but just not used to I just was asking if it was normal....thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">check the rear mount,maybe its touching the body</TD></TR></TABLE>
will do
will do
Mishako129
May 18, 2013 07:34 AM
DaChoZn1
Jan 6, 2011 08:45 AM
White HB
May 15, 2003 05:47 PM
