NEW: JDM ITR Shift Boot
New ITR shift boot from password jdm.
bought the boot a week ago for my del sol and it said it would fit but didnt...
its out of the orginal wrapping but ill send that two if u request it cause i saved it!
my loss and ur gain!...this is authentic oem jdm for your Integra!!
ask for real pictures!
cant you just use your stock metal bracket from your del sol and clip the boot onto it? the itr boot might not be the exact same cut as your stock boot, but i imagine you could modify it to fit and you wouldnt even be able to tell when installed.
you can. I did its really easy.. all you do is put it where it should go on the del sol shift boot bracket, then take a razor blade, and cut it where teh tabs are, and put it in.. real easy to do, took like 30 sec.'s lol.. good luck
ok heres the issue now..i tried to make it fit so i put several slits in it by a razor the orginal slits are there and it still bolts on to the orginal bracket the slits i made are comletely un noticeable when its on the car! so i will be willing to part cheap with it other wise its brand new other that the slits..it will come completely installed to the bracket so all u have to do is install it and ignore the extra slits which are small razor blade slits!
del sol1658
12
Nov 29, 2006 07:18 PM
teknoracing
May 28, 2006 02:02 PM
