headlight install
im about to install some type R headlights, i just need to know if this is an easy plug and play install, any specific tools that i will need? what can i do to prevent the headlights from being installed crooked? also this isnt my car, this is my gfs car, so ive never worked on a car like this (not like the project is anything complex)
TIA
TIA
what peice was that?? i deff dont want to break something that expensive, especially if its not my car im working on...i dont plan on changing any bulbs, just taking out the housing for the bulb, i guess you could say, and installing a whole diff headlight
Headlight installs on Hondas or Acuras usually require a 10mm socket to remove the headlights once the bumper cover is removed. Nothing major...should be pretty easy if you like taking cars apart. I give you props for helping your friend out. Not everyone was born to use tools. HAHA Good luck
