Definitive way of finding out whether fuel is getting to cylinders
Old Oct 7, 2006 | 02:10 PM
vinuneuro's Avatar
Default Definitive way of finding out whether fuel is getting to cylinders
I know I'm getting fuel to the rail. I'm not sure if it's getting to the cylinders though.
Old Oct 7, 2006 | 02:20 PM
darkspector2.0's Avatar
pull out the injector and spray fuel all over your engine bay? LoL
Old Oct 7, 2006 | 08:28 PM
snzh22's Avatar
Default Re: (darkspector2.0)
i think my friend pulled an injector and saw no change in his engine on his 240. thats how he figured which one it was. if it was working fine, after its pulled, you should see the engine bog or shake or just get disturbed in general. i think thats what he did, and it makes sense. im pretty sure its the same concept with checking plug wires.
Old Oct 7, 2006 | 08:35 PM
mgags7's Avatar
guys you cant just pull and injector....lol where's it gonna get fuel from?
node light ftw
Old Oct 7, 2006 | 08:55 PM
vinuneuro's Avatar
Default Re: (bb4ever)
bahaha...yea
How exactly does a node light work?
Old Oct 8, 2006 | 10:37 AM
PirateMcFred's Avatar
Default Re: (vinuneuro)
Pretty much works like a timing light. Put a little induction coil on the injector wires and then crank it. If the injector has fuel pressure and an electrical signal then it will probably open and squirt some fuel.
Another option: If you keep cranking the engine and it does not start and the exhaust eventually smells like fuel, pull a spark plug and see if it reeks like gas. Then you probably have an ignition issue.
Pirate
Old Oct 8, 2006 | 11:14 AM
All-Motor-Junkie's Avatar
can you hook up a osciliscope to the injecter wires and read the current? im sure theres some specs for that ****, but like pirate said if spark plugs smell like fuel most likely a spark prob
Old Oct 8, 2006 | 11:30 AM
mgags7's Avatar
Default Re: (All-Motor-Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor-Junkie &raquo;</TD></TR><TR><TD CLASS="quote">can you hook up a osciliscope to the injecter wires and read the current? im sure theres some specs for that ****, but like pirate said if spark plugs smell like fuel most likely a spark prob</TD></TR></TABLE>
you certainly could...the injector pulses are duty cycle varying square wave signals...correct me if i'm wrong....
Old Oct 8, 2006 | 01:17 PM
v4lu3s's Avatar
RTFM
i usually use an injector test light to see if i cam getting pulse to the injectors.
Old Oct 8, 2006 | 05:59 PM
2point2's Avatar
Smell test.
and if it fails:
Continuity to each injector and to the resistor box.
and if that doesnt fix the problem:
try a friends ECU and resistor box
Still screwed?
get the injectors tested.
and if that fails:
but a new Prelude.
Old Oct 8, 2006 | 06:24 PM
DJ_SaNdOz's Avatar
Default Re: Definitive way of finding out whether fuel is getting to cylinders (vinuneuro)
I just use the injector test lights just like a few others appear to be using
Old Oct 9, 2006 | 09:44 AM
vinuneuro's Avatar
Default Re: Definitive way of finding out whether fuel is getting to cylinders (DJ_SaNdOz)
I don't have access to a node light, so I'm going to try checking alternating current at the injector plugs. However, there are two pins, how should I go about doing this?
Old Oct 9, 2006 | 10:16 AM
vinuneuro's Avatar
Ok, I checked the voltage at the injector plugs while they were disconnected. I got a reading of 29.5. I thought the voltage was supposed to be 12v?
Old Oct 9, 2006 | 11:14 AM
mgags7's Avatar
Like I was saying, they use a square wave AC signal....was that measured with the AC function on the multimeter??
The ecu would be perfectly capable of generating a waveform with that amplitude, though I would like to see what settings you used to test with....
Old Oct 9, 2006 | 11:33 AM
vinuneuro's Avatar
The multimeter was set to AC 200.
tkda
16
Mar 17, 2009 09:58 AM
TylerC161
Dec 13, 2006 08:58 AM
tRex99
11
Oct 27, 2004 06:01 PM
freud
Feb 26, 2003 02:01 PM
