One headlight out...
So my passenger headlight (lowbeam) is out. I tried replacing the bulb thinking it was a dead bulb. However the original light is fine and the new bulb doesn't work either. I switched the fuses and that didn't work either. Anyone know the problem? The High beam works just fine as well as the small parking light.
Checking for power is first, using a wire diagram is next working your way back to the light switch, take it out and look for the burnt spot, then change it if needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan »</TD></TR><TR><TD CLASS="quote">Checking for power is first, using a wire diagram is next working your way back to the light switch, take it out and look for the burnt spot, then change it if needed.</TD></TR></TABLE>
i also need help my jdm driver side headlight low beam is out i switched the bulb to the passenger side and it works i checked the fuses they were fine. What could it be the h1 harness(i think its from a civic)? i will switch the passenger and drivers side tomorrow and see if that works.
ed2
Jun 8, 2010 11:09 PM
OMG naD16 lol
Dec 13, 2006 09:19 AM
integraracing91
Dec 3, 2006 03:43 PM
