Cleanin up Basement SALE
Cleanin up the basement
Stock B16 header
88-91 EF Stock Si Muffler (VERY MINT)
LS Oil Pump (missing spring inside)
EF Map Sensor & other Vac
90-91 EF Hatch Clear Corner(Driver side cracked and broken tab)
SOHC Timing Belt Tenisior
90-93 Clutch Cable
Bseries Stock Cam gears
B16 Timing Belt
Fuel Rail (2)
Fuel Pressure Reg.(3)
EF Throttle Cable
B16 Head Studs
PR4 Rear Seal Cover
Bseries Pressure Plate
LS Main Caps
LS Main Caps Bolts
EF Stock Headlight bulbs
Speedi Boot CV Joint Split Boot repair kit
unknown Midshaft(looks like 90-93 teggy)
Exhaust Donut Gasket
Everything is best offer
Modified by TurboTealEF at 1:56 PM 10/9/2006
Stock B16 header
90-93 Clutch Cable
B16 Timing Belt
Fuel Rail (2)
EF Throttle Cable
B16 Head Studs
PR4 Rear Seal Cover
LS Main Caps
LS Main Caps Bolts
