Passed smog, but high HC??
Got my car smoged this morning, and I was amazed it passed, Everything looked but but the HC count. Fail is 61, mine was at 60.
Car was hot, I drove on the freeway for about 15min, and the streets for another 10min, Shut the car off for 4-5min, pulled it in the bay and let it idle at least 5 min before he did the test. Oil and Water temp both looked good before the test. Fresh oil, Plugs, Cap, Rotor,Wire,Radiator fluid (all have about 40mi) Reset the ECU when I did all the work.
What would cause a high HC? Cat? O2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR »</TD></TR><TR><TD CLASS="quote">could be the cat... </TD></TR></TABLE>
Sounds like a bad catalytic......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazw8st »</TD></TR><TR><TD CLASS="quote">Sounds like a bad catalytic...... </TD></TR></TABLE>
The man, the myth, the legend. You are all over the web, and are well knowen for you smog!
I am glad it passed, but I had a feeling it could be the cat and/or an 02 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">The man, the myth, the legend. You are all over the web, and are well known for you smog!
Smog exemption is the only way to go! That is great that you passed.......
I was amazed. I had about 1/2 tank of 3yr old gas, with 1/2 tank of new gas, along with a fuel system cleaner stuff. And it was a legit pass, it was a smog station that my wifes dad knows. We talked and I told him I really doubt it will pass, he was cool and said if it did nt pass he would help me out getting it to pass, meaining loaning me a cat if I needed it...etc
