Someone has to know what causes................
Old Oct 7, 2006 | 07:56 AM
96azure's Avatar
Default Someone has to know what causes................
My car spent all day yesterday in shop number two. It seems to be arcing between the spark plug boot and the head. He swapped the wires and it still does it. It does it when you rev it up above about 1500 rpm.
Is it a short in something?
Old Oct 7, 2006 | 08:06 AM
v4lu3s's Avatar
RTFM
tried new plug wires yet?
Old Oct 7, 2006 | 08:29 AM
Hawkze_2.3's Avatar
Default Re: Someone has to know what causes................ (96azure)
Yeah, try new wires if you haven't. Where is it arcing? Near the distributor or at the valve cover boot or what?
Old Oct 7, 2006 | 04:32 PM
96azure's Avatar
Default Re: Someone has to know what causes................ (Hawkze_2.3)
New plugs, new cap, new wires, sending it to a BMW guy next week. The local Honda/Acura experts said they don't know and basically don't want to be bothered.
Old Oct 7, 2006 | 05:28 PM
hella_usdm's Avatar
check all the grounding points.
Old Oct 7, 2006 | 05:44 PM
96azure's Avatar
Default Re: (hella_usdm)
They checked those also. The BMW is confident. He has like six techs.
Old Oct 14, 2006 | 07:46 PM
96azure's Avatar
Default Re: (96azure)
Well, they did the valves and I quess one was too tight. It doesn't die but is still arcing between the plug lead and the head.
Anyone know why it does this. Too much voltage coming out if the coil, maybe?
Old Oct 14, 2006 | 07:51 PM
madcatz's Avatar
whats your ignition system consist of?
what modifications if any have you done to it.....your asking a very vague question here for internet troubleshooting
Old Oct 14, 2006 | 10:16 PM
96azure's Avatar
Default Re: (madcatz)
My mechanic says for some reason it's arcing between the plug boot and the head. New wires and plugs. They have even been swapped out. Ground is good. The car is bone stock. No mods.
Evidently, no one has ever seen this before in the history of Preludes..........
Old Oct 15, 2006 | 02:02 AM
TheWalrus's Avatar
no one has ever seen this in the history of cars cuz it doesnt make sense...maybe the spark plug threads are corroded so bad that spark cant be grounded there?
zellmk
Dec 9, 2015 09:53 PM
lsvtechatchy
May 13, 2010 09:26 AM
Elite Hatch
Jan 15, 2003 04:31 PM
Wazup
Nov 11, 2002 01:15 AM
Diversion
Mar 2, 2002 03:04 PM
