Touch Up Paint for Fit Sport Rim
The Fit Sport wheel face is just machined and clearcoated alloy. The sides of the spokes are painted, but I'm guessing you scratched a wheel face rather than the side of a spoke. You could try using touch-up paint intended for clearcoat... it should be available at most auto parts stores.
I'm not sure any corrosion would be any problem. Aluminum doesn't continue to oxidize like the iron that turns to iron oxide (rust) in steel does. Aluminum oxide on aluminum forms in miliseconds after exposure to air and ends the corrosion process. But, I'm not sure if it becomes a problem with the clear-coat or paint on the wheel.
