where to get grade8/metric10.9 nuts & bolts?
Old May 2, 2002 | 04:48 PM
magic hat #9's Avatar
Default where to get grade8/metric10.9 nuts & bolts?
i have my new sparco evo bucket with base/rails sitting here in my living room but i can't find the proper nuts & bolts. i've tried 2 pep boys and autozone sucks. is the grade 5 stuff they have at home depot strong enough for this application? anybody know a mailorder place that carries strong hardware? any fellow connectifucks know a place in the stamford area that might carry this stuff?
Old May 2, 2002 | 05:03 PM
D's Avatar
D
Default Re: where to get grade8/metric10.9 nuts & bolts? (monkey_truckR)
p boys usually has a very good selection... try another.
D
Old May 2, 2002 | 06:31 PM
norice's Avatar
Default Re: where to get grade8/metric10.9 nuts & bolts? (D)
Actually, Pep Boys has a pretty awful (and overpriced) selection (at least the three that I visited had).
Try Home Depot - or Orchard Supply is even better (if you have them in your area).
Old May 2, 2002 | 06:35 PM
yoshi234's Avatar
I shoot brides
Default Re: where to get grade8/metric10.9 nuts & bolts? (norice)
yshi - who agrees w/ n'rice
Old May 2, 2002 | 06:45 PM
MackSpeed-616's Avatar
Default Re: where to get grade8/metric10.9 nuts & bolts? (yoshi234)
i have little luck with metric chit at home depot. out here with have these little places still left called "hard ware stores" the ones that havent been run outta town by the big boys still carry metric hardware... try a "servistar" if you have one.
Old May 2, 2002 | 07:18 PM
Gump's Avatar
i had this same problem looking for 10.9 bolts! look in the yellow pages under nuts and bolts, or bolts and nuts, and you should find a specialty shop that sells them. i found a shop near me that sold bolts that looked like stock except that they were silver instead of bronze
[Modified by Gump, 8:21 PM 5/2/2002]
Old May 2, 2002 | 07:34 PM
i talked to home depo(si)t on the phone, their highest grade is 5. is this strong enough to use for seat mounting?
pep boys does carry the proper hardware, but they do NOT restock them regularly. the local pep boy said they do not make an effort to keep things stocked or organized. napa is out of stock. autozone is a joke.
Old May 2, 2002 | 07:38 PM
Dr Pooface's Avatar
Grade 5 is fine. Grade 8 would be better, but I wouldn't worry about it.
Old May 2, 2002 | 07:53 PM
Default Re: where to get grade8/metric10.9 nuts & bolts? (Gump)
"nutty company" under "bolts & nuts"
i will be speaking with them tomorrow.
does anyone know the difference between grade 5 and grade 8?
Old May 2, 2002 | 07:55 PM
Dr Pooface's Avatar
Grade 8 is stronger. I know that doesn't help.
Old May 2, 2002 | 07:56 PM
norice's Avatar
Orchard Supply has some nice 12.9 grade metric bolts. I'm also using them to mount Evo seats. Look under 'Fasteners' in your local yellow pages.
Old May 2, 2002 | 08:16 PM
orchard supply looks to be california only........there may be further points from connecticut, but..........haha!
Old May 2, 2002 | 08:17 PM
Kengs's Avatar
MSC has EVERY conceivable type of nut/bolt/fastener you could want.
http://www.mscdirect.com
[Modified by kengs, 12:22 AM 5/3/2002]
Default Re: where to get grade8/metric10.9 nuts & bolts? (Ddub)
one step closer in this search!
Old May 3, 2002 | 02:45 AM
Racebrewer's Avatar
Look in phone book for a company named "Fastenal". Huge fastener retailer with over 600 outlets nationwide, They also have an on-line catalog
John
Old May 3, 2002 | 03:36 AM
Ricky Rojales's Avatar
I've found some at TrakAuto, too... And PepBoy's selection would be great if bolts were in the right bins... or that they would at least maintain inventory.
Old May 3, 2002 | 04:43 AM
Default Re: where to get grade8/metric10.9 nuts & bolts? (Fluoxetine HCL)
check what aleph sent me:
http://raskcycle.com/techtip/webdoc14.html
http://www.futek.com/boltcalc.asp?boltmode=metric
it explains the difference between grade 5 and grade 8 and how to tell them apart. it looks like grade 8 bolts are about 25% stronger than grade 5 (not sure if i'm right though).
Old May 3, 2002 | 03:44 PM
Racebrewer's Avatar
Yup. Grade 8's are stronger than grade 5's.
In metric ratings the strength goes up as the number increases (8.8, etc) also.
Aircraft are stronger yet and less likely to break. 8's should be more than good enough and stronger than the seat or the floor board that its mounted to.
John
Rain_man
Jul 2, 2008 04:15 AM
WayQuiz
Dec 31, 2005 03:59 PM
HmgLauj69
Oct 14, 2004 01:40 AM
