Throttle Cable gets stuck?
One of my friend call me this morning and said his throttle cable gets stuck when he press the gas pedal. I went to take a look at it and the throttle valve seems to move smoothly, so that wasn’t the problem. When I get in and take a look at it, I hear this noise (sounds like a zipper closing) when I press the pedal. It seems like the throttle cable gets lock at some point but I really cannot figure it out. My prediction is somewhere near the firewall but I’m not too sure. Anyone ever had similar problem?
It could be a defected cable or spring but I wanted to get some advice 1st before I start any work.
well if the throttle body moves smoothly by hand then it's got to be the cable or pedal assembly. just give it a visual inspection in the driver's footwell pressing the pedal back & forth.....
you might find a bracket bent & rubbing the pedal or something
bayoufrogg
Jun 5, 2007 06:25 PM
rolledthatho
Sep 9, 2005 10:29 AM
