are all swap moutns for all b series engine???
It depends on the mount kit that you buy there are comanies that make kits for the H series as well but if you do end up gettin' a B series mount kit, it will bolt up to any B series motor.
Place racing, HASport are the first two anyone will tell ya to get, I got the Place and the motor is in perfect positioning. And you'll probably have to get the shift linkage from the same manufacturer.
actually...... i tell everyone I can to stay AWAY from Place racing..... I hear too much bad **** about them.
HAsport makes real quality ****, and I hear the new HCP kit isnt that bad at all.....
And yeah, all b series mounts work with B-blocks, provided you are using the correct mounting brackets and such......
a lot of these companies had 2 series of mounts like place racing and hcp, ask before you order them, ive seen some extremely thin mounts but then seen thicker mounts made by the same company. Sometimes they just got old stuff laying around that they try to get rid of.
delboost
May 20, 2008 08:42 AM
SloCivicHMM
Apr 3, 2003 02:24 PM
