SOHC Cheap Thrill...
Old May 2, 2002 | 04:39 PM
Undrstm8ed2's Avatar
Default SOHC Cheap Thrill...
Just had some interesting fun to share. 92 civic cx with dx transplant, ( yea i know, why?) but anyhow this combined with 94 Si tranny, ngk wires & plugs 13 in steelies and rear seat pulled, gave a surprising 16.5 quarter at 82 mph. slow exit of the quarter do to low tire pressure it was fallen on its face cause of the excess weight being thrown could have been 16.3-16.4 with proper pressure. Now iv'e added a91 Si head (yep 91 had much better and larger valves and tb.) newer si ECU newer times 14.57 quarter with upper 90's speed. if you were to take this and add a bottle i believe it could achieve upper 12's to lower 13 sec quarters... dont know if this has been done before but a friend of mine fanagled this setup and i must say for a sohc, i was stupified at its ability also should share that this head was port & polished and decked about .80000 ( yeah ! ). just wondering if anyone has done simialer things?
Old May 2, 2002 | 04:45 PM
eg6ajk's Avatar
Default Re: SOHC Cheap Thrill... (Undrstm8ed2)
check with Mista Bone he is the man when it comes to cheap and quick SOHCs
or read http://pub34.ezboard.com/fhondadseriesfrm2
Old May 2, 2002 | 05:53 PM
MaxBoost's Avatar
New User
Default Re: SOHC Cheap Thrill... (eg6ajk)
My stock DX hatch. Completely stock. Full Interior, stock timing, spare, a/c, everything...went 16.50
My friends CX had a dx bottom with a ex/si head..open dc header, vafc, aem cai, and home port and polish..went 12.90 on nitto nt555r's and an 80shot.
Old May 3, 2002 | 04:59 AM
Mista Bone's Avatar
D Tranny Guru
:cough:cough:bullshit!!!!!!
Stock DX will run 16.2
88-95 SOHC 16 Valve non vtec heads are all the same except for the valvesprings and cam.
You milled over 3/4" of a inch off the head? Let alone cam timing issues, what timing belt did you use?
FYI stock DX HB with I/H/E/CRX Si cam nets about 135 hp at the crank and runs 15.0s with a close ratio tranny and slicks.
Bullshit posting *******!!!!!
Old May 6, 2002 | 01:39 PM
Default Re: SOHC Cheap Thrill... (Mista Bone)
[QUOTE]:cough:cough:bullshit!!!!!!
no not 3/4 of an inch bone. 3/4 of an inch would be hmmm no valve seats left which is what i'm assuming your getting at no it was actually 80,000 thousandths shaved off... sorry if you miss-understood what i meant... and according to hearsay from the factory (Honda) stock 1.5 litre dx new out of the box was 16.7 under more than perfect conditions but your imput was welcomed....
Old May 6, 2002 | 04:08 PM
owen_the_soyboy's Avatar
80 thousandths is 0.080
maybe this will help, prolly not.
easy to remember because you can just barely fit 999 into 1000
so, 0.999 is 999 thousandths.
add 0.001 and you have a full inch.
math is fun.
Old May 6, 2002 | 04:53 PM
Turbo Laser's Avatar
Default Re: SOHC Cheap Thrill... (owen_the_soyboy)
So is this bull?
Old May 6, 2002 | 06:35 PM
l's Avatar
l
hhhhmm maybe one of the men.... THE MAN of cheap quick SOHC's doesnt come on this board... but he spent like 750 and ran 12s allmotor sohc....
disclaimer ( he spent= he has hookups on alot of stuff)
Old May 6, 2002 | 06:44 PM
JaeOne3345's Avatar
Default Re: SOHC Cheap Thrill... (IM ALL SHO)
93 dx coupe(yeah the coupe..what everyone hates on) bone stock no milling or none of that shiut..16.2 at 84mph with shitty launches and 60 fts
Old May 6, 2002 | 06:56 PM
trix are for kids's Avatar
what mods?
CALM_AS_A_BOMB
64
Mar 13, 2006 06:35 AM
CRXSleeper
12
Sep 9, 2002 02:13 PM
si91
19
May 20, 2002 04:59 AM
