My car almost lost control, TWICE!
Old Oct 6, 2006 | 10:33 AM
AnthraxVX's Avatar
Default My car almost lost control, TWICE!
so ok, here is the deal, my 91 integ with gsr swap is having an issue. it was vibrating/shaking under accelleration so i changed axles, still did it and then i looked and the autozone axle was fucked up that they gave me. returned it and put new one in. drove to san fran from san diego and on the way back was goign 80 ish and dropped into 4th to race someone hehe. and then all of the sudden it started pulling right HARD and it sounded like somethign was hitting and rubbing., i look at it for a sec and the passenger axle, the rubber inner cv boot, is rubbing against itself, (the boots flaps are rubbing against itself and making a squeeking noise) but both axles are in and good so i start driving again and it keeps squeeking and pulling for a minute then it goes away. 4 days later same thing happens except at about 20 mph, pull over and rotate my steering wheel and kinda swerve and it goes away.... and here i am im confused..
the wierd thing is that the axle stops rubbing against itself .. very wierd like the axle is getting longer and then not haha. very wierd..
so wut can it be? can it be my steering rack? cuz i think that might be going bad..
my camber kit? i checked it and it looks all tight and i tighten them so not sure..
alignment? i dont think it would cause that.. any ideas will help. thanks so much
thanks ahead of time and sorry for the LONG explanation, just dont know really how else to explain it. haha.
Old Oct 6, 2006 | 12:02 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: My car almost lost control, TWICE! (AnthraxVX)
Have you taken off the wheel and checked the hubs? Maybe the bearings are going out? I'd check everything related to the suspension. Maybe some bushings are torn up?
Good luck and be careful...
tamadrummer1120
Oct 13, 2009 07:48 AM
importdude2000
Feb 1, 2007 09:36 AM
gospeedgo1
18
Oct 25, 2005 06:25 PM
AaronJ
11
Dec 3, 2003 09:37 AM
leadfoot78
May 26, 2003 12:17 PM
