torque mounts
Old Oct 6, 2006 | 02:45 AM
De_tour's Avatar
Default torque mounts
Modified by De_tour at 3:00 PM 5/2/2007
Old Oct 6, 2006 | 03:11 AM
Timmay's Avatar
Default Re: torque mounts (wspcivic)
i would say get hasport replacement mounts or the ES insert kit.. i would think that the tq mounts would still fit though
Old Oct 6, 2006 | 04:40 AM
instrument's Avatar
that exhaust will be scary loud.
i pray you have earphones of some sort to wear.
wish i could get my car painted
Old Oct 6, 2006 | 06:31 PM
De_tour's Avatar
Default Re: (instrument)
Old Oct 6, 2006 | 06:37 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
I would at the very least get a rear mount insert. I run a full set with no torque mounts. No probs.
Old Oct 6, 2006 | 06:46 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (THE GUY)
if ur not going to run torque mounts, I think u should at least get some perfomance mounts, like hasport or innovative. Those are stiffer mounts and can withstand way more beating than stock.
Old Oct 6, 2006 | 06:53 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
With the power that thing looks like it will make, you should get at least a rear mount if not an entire set of performance mounts. Only makes sense.
Old Oct 6, 2006 | 09:43 PM
VTAC-KAT's Avatar
I ran my b16 without that tranny mount and shitty stock mounts for about 10 months and 10,000 miles. Nothing happened even under spirited driving but the difference with it installed is noticeable.
Are you worried about clearance issues with your header?
Old Oct 6, 2006 | 09:48 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (auctionaccess)
For the last time: the two front torque mounts aren't there to keep the engine steady. They're designed to soak up vibrations from tiny imbalances and your average changes in acceleration and direction. It's not a structural thing, it's a comfort thing, and even if you don't have them at all you probably won't notice. If you're worried about the engine moving around, don't. If you're worried about possibly 5% more vibration, get a torque damper and some inserts.
But no, it's not going to hurt anything to run it like that. Surely you've seen the milimeters-thick web of "connections" that hold the torque mounts to the unibody. I don't think any real human being could look me in the eyes and say they did jack ****
92lxsleeper
Jul 29, 2009 08:28 AM
Boner_Ben
Welding / Fabrication
Sep 29, 2007 02:04 PM
dr_latino999
Mar 26, 2007 12:19 PM
crxsiperf
Apr 8, 2006 08:01 PM
rondigs
Jul 21, 2003 06:26 PM
