Help with 4ws codes 70 and 29
Old Oct 5, 2006 | 10:17 PM
Ludefun's Avatar
Default Help with 4ws codes 70 and 29
I have a 1992 Si 4ws. I realize there is a ton of threads out there dealing with this topic, but I can't seem to narrow down my problem. This has been an ongoing problem for about 1 year. It started with an error 62, I found that write up and took care of that code. At the same time, I replaced alot of suspension parts: struts, springs, front upper control arms, front lower ball joints, rear upper ball joints, various bushings..etc. That lowered my car slightly, but it's not _low_ by any means. Anyways, after all that, I took it to the honda dealer and had it aligned. For about 4 days, things were going pretty good. Then the light came back on and I believe it's throwing codes 70 and 29. Also, something I've noticed and asked others to look at. It appears my tires look somewhat like this from the rear | \ not quite that bad, but the right rear seems to be in on the top. Strangely enough, I'm wearing the inside of that tire. I'm several sets of tires into this problem as is, any advice and guidance would be greatly appreciated. Thanks in advance.
Old Oct 6, 2006 | 06:01 AM
sean1121's Avatar
Default Re: Help with 4ws codes 70 and 29 (Ludefun)
Code 29 is the rear steering angle sensor, get a copy of the service manual and do the troubleshooting for it.
Old Nov 7, 2006 | 10:50 AM
Ludefun's Avatar
Default Re: Help with 4ws codes 70 and 29 (sean1121)
I'll go ahead and bring this one back up. Could anyone be more specific on what type of service manual I need? I need something more detailed than the Chilton's I currently have. Thanks.
On another note ( just got off the phone with the honda dealership that did my last alignment ) they're trying to blame my tire wear on it being lowered. That's BS right? if they're a suspension "technician", my car shouldn't be a problem for them should it? It's not lowered nearly as much as alot of cars I've seen on this forum, maybe an inch at the most.
Old Nov 7, 2006 | 11:12 AM
kulrevon's Avatar
https://honda-tech.com/zeropost?cmd=tshow&id=886363
This is the full honda prelude manual. all 1400pgs of it.
http://www.simnets.com/pub/car...e.pdf
jerimint
Honda Civic (2006 - 2015)
116
Jan 2, 2012 02:53 AM
elemntsk8r16
Oct 12, 2011 01:26 PM
markturbo
13
Sep 17, 2010 08:26 AM
CRX MASE
Suspension & Brakes
75
Jan 27, 2008 08:01 AM
Reid
Dec 9, 2002 07:05 AM
