help with a rewire
before i got my car a swap was already done and the guy messed up the wiring really bad so i have decided to rewire every thing. i have all the harnesses on the way and i was wondering if any of you have a wire diagram that i can follow so that i plug every thing in right and get all my grounds right. by the way its a 88 crx and the wire harness that im getting is from a crx si.
levi
levi
what model of crx do you have?? the si harness will work in a hf motor, couple different wires, otherwise if u have a dx motor, DPFI (dual point fuel injection) u prolly should invest into a MPFI engine, d16a6, something with 4 injectors, instead of the DPFI has one main injector than a back up pm me if u have questions
you have an 88 which means you can only use an 88 harness....89-91 is different,,,,if you have an hf get an hf harness..dx,get a dx harness..si,get an si harness....now if you have an si or hf your straight just get the harness plug it in and add the 4 wires for vtec,,,but if you have a dx you gotta convert to mpfi ,and add the vtec wires,,,for a wire diagram do a search on here or google it..you'll find it
scooterbuilteh2
10
Sep 4, 2009 10:31 AM
KevronsEG
Nov 20, 2003 07:57 AM
