3rd gen accord horsepower
What is the most horsepower that i can get out of my accord a20a3 engine with header, intake, msd, trottlebody change, and msd ignition. which larger accord trottle body would be able to fit my 3rd gen
would a chip of any sort help me out on horsepower. I finally have some money and I am trying to make my car faster without changing the engine.
I thought it was 300 hp... well close enough...
There is the build it yourself programable fuel management system you can get.
From the looks of the PC interface, you have many variables you can change to tune the chip for added performance.
ask jballut oO?, he has the crankinest 3rd gen around turbocharged A20 motor, but i think he is in the high 200's?
Yes I know I am active, it is a hit and miss kind of deal..
With the new mods that I am doing, I am hoping to get 400whp out of this motor. When everything is said and done, I will have the car dynoed and run it at the track so I can get into the number game...
is that with the stock motor? if so, how many miles do you have jballou? do you have any tips for turboing a honda motor(f22b1) with stock internals? what precautions should one take?
thanks
thanks
How about a detailed list of mods and future plans? Please, please, please
yu0!!!!
are the shizzle man
Extream warning (long list)
This also includes all the stuff I have waiting to be installed
Current mods:
Engine:
A20A3 Cast Iron Block (sonic tested/magnafluxed)
JE 8.5:1 Pistons (Custom Made)
Crower Rods
Hastings Rings
Stock valvetrain
Turbo Manifold (Custom Made)
Turbonetics T-3 Super 60 Turbocharger
3" downpipe (custom)
Turbonetics DeltaGate Wastegate
Turbonetics Manual boost controller
MSD BTM
MSD wires
NGK plugs (2 steps colder)
Vortech Fuel Rail (custom brakets)
RC 500cc Peak and Hold injectors
Vortech FPR
Aeromotice Fuel pump
Aeromotice Fuel Filter
Custom Ceramic clutch (unsprung hub)
Pace Setter short shifter
DC sports Front Strut bar
Rear strut bar (custom)
KYB struts
Eibach sportline springs
Powerstop Rotors F/R
Rear disc brake conversion
Haltech EK6 (still needs to be hooked up)
HKS BOV
Spearco intercooler
Misc. braided fuel lines and fittings
1/2" fuel line from tank
Indigo gauges (Custom Made)
Adj. cam gear (custom Made)
A-pillar pods (3) (custom Made)
Greddy Turbo Timer
SOlid Aluminum motor mounts
delrin inserts on other bushings
MSD blaster coil
Ingalls camber kit (F/R)
Prelude upper arms (Front)
Axis Touring cups 16" (rims)
Battery moved to rear
Plexi glass rear hatch
There is more to come, just thinking of what is off the top of my head....
Current mods:
Engine:
Crower Rods
Hastings Rings
Stock valvetrain
MSD BTM
MSD wires
Vortech FPR
KYB struts
HKS BOV
Spearco intercooler
Greddy Turbo Timer
MSD blaster coil
Dude, if you dont come around and participate more often in our conversations, I will be forced to feed you a PP&J sammich!!
Anyway, how much boost are you currently running and planning to run?
Before I tore everything apart for a re-fresh, I was running anywhere from 18-22psi, basically maxing out the turbo (I think, I will find out if I am or not when I dyno the car.)
